Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
It says I can not record pick the asio duplex but i don't know how
    Novelist:
  • 146 Answers
What recording software are you using? What version of Windows are you on? The ASIO driver for the Lambda should have been installed when you loaded the software that it came with, and if so there should be a control panel that will allow you to select that. The other option is to use ASIO4ALL. It is a free ASIO driver that works really well for most sound cards and software instruments and recording software like Cubase, Nuendo or the many other programmes out there.
If you need more help let me know.
Cheers.
Posted on Dec 27, 2008
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
I have the cubase le 4 and, everything installed fine but when i went to record nothing was happening the cursor moved across the screen but wasnt picking up any sound. i also got a message saying that the...
Try downloading Asio4all at http://www.asio4all.com/ and carefully following their instructions. There is good information under the FAQ/Troubleshooting section on their site. Id also recommend joining Recording Review for some great info. I think you can reach them through recordingrev001@aweber.com. Hope this helps.
Jul 09, 2009 | Lexicon Lambda 4x2x2 USB Audio Interface
WDM or ASIO drivers in LynxOne?
Go with ASIO for reduced latency. Preferably the ASIO driver available for your card at the LynxStudio.com web site.
Mar 16, 2009 | lynx studio LynxONE Sound Card
H4 randomly stops recording on cubase le
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Aug 28, 2008 | Zoom H4 Handy Recorder
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
PLaying and Recording
Look in your MIDI instruments and make sure the icon for you to play back is lit.
Apr 20, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Mar 31, 2008 | Lexicon Omega Desktop Recording Studio...
EMU 1616m (cardbus) not offerring its input sources to Reaper
While you probably solved this already here goes. I'm not familiar with reaper but most audio recording software can select between using windows wdm & ASIO. If you aren't set to ASIO you won't be able to see the Hi-Z (Dock A/Dock B) inputs. It looks like Reaper supports ASIO so that should be fine. If though you are using a program that doesn't support ASIO you need to use the EMU patchmix and 'patch' the input through to a 'wave' channel.
Mar 19, 2008 | E-Mu 1616M Sound Card
My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
132 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
