Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
My 500GB Mybook world edition's mother board died.
Okay so my 500GB Mybook world edition's network card and motherboard died. I took the case apart and slaved it to my computer's SATA port. in the Bios it reads it just fine, and when i'm in Windows XP it' sees the drive. but when i try to access any files on the drive it says the drive is not formated. is this becuase the drive is formated in a NAS language other than an NTFS or a FAT32? if thats the case is there a way of access my data? Please help.
Thank you
Brandon
  • ocdrichard Jan 09, 2009
    I've got the drive removed and installed the ext driver for windows to read Linux and it stills gives the error or "needs to be formatted".
    Problem Solver:
  • 10 Answers
Contact DataMajic at www.datamajic.com to get the data off.
Ebay seller- datamajic
Posted on Jan 01, 2010
    President:
  • 1,179 Answers
It's the format that doesn't allow windows to access the data. Only way to recover is to get another external drive and transfer the data to it. Then you could reformatt the old drive to work with XP. Hope this helps.
Posted on Dec 23, 2008
The HDD is formatted in ext3, not NTFS or FAT32.
You need to use Linux or get an ext3 driver for Windows in order to access the files.
Further advice can be found here: http://mybookworld.wikidot.com/
Posted on Dec 29, 2008
Mybook 500gb shows 2199gb and cannot be read
This drive has been misformatted. You will need to plug the drive into your windows computer. Hold down the windows key and tap the e key. In the window that appears, find the MyBook drive. Right click and choose format. Select the quick format box. Make sure file type is set to NTFS. Click "Format". This operation will however remove all data on the device.
Apr 20, 2011 | Western Digital 500GB My Book World...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
I can not link up with My Book World Edition 500GB
That is because the MyBook is set with a default IP address of 192.168.1.257. You will have to put a static IP address in that subnet range in order to be able to see the external drive. Hope this helps....
Dec 13, 2008 | Western Digital 500GB My Book World...
I have an wd 500gb external hard drive.it will not power up. i think it is the transformer does anybody know where i can get one or fix it?
With voltmeter, check voltage from the transformer if you think it is a power issue. If it is faulty, Radio Shack may have something with the right size connector and voltage. Ebay is another option. However be forewarned that MyBook by WD are known to blow up the drive controller board. My 500GB "World Edition" did so after 1.5 yrs. Drive spins but no access. Took controller board out and found burned chip pins.
Dec 08, 2008 | Western Digital 500GB My Book Pro-External...
Slow WD World Edition HD
I understand your pain. Mine was always slow, but it's by design. I am sure the limitation is the amount of RAM it has, because everytime it needs to access data, the RAM is so small that it will have to go back to the drive just to re-read an index. When mine died after 1.5 yrs, I took it apart and found a WD5000AAKS SATA 7200rpm drive. Performance of the drive should be excellent, but in that little plastic box that is acting like a stand-alone NT server, performance is s-l-o-w. As a MyBook, it's best used as a backup unit, but be sure you have a backup of that, since it is highly unlikely it will live much more than 12 months, if that, because it has no forced cooling. See other issues on this site with regard to other MyBooks.
Dec 02, 2008 | Western Digital 500GB My Book World...
WD Hard Drive Not Detecting
Yes, this can be done via the user web interface, by typing in mybookworld or wdstorage into the web browser and the shared storage manager should come up. If you go to general setup there should be an option to update network settings.
Oct 31, 2008 | Western Digital 500GB My Book World...
Cant download large files to my book
The controller board in Mybook might not support files over 4 gb. Check with the manufacturer if there are any new drivers for you product to solve your dilema. You could also just buy a cheap external case for the drive in the mybook and swap it out. None of the new cases have these limitations and you can get them online for less than 20 bucks. I like MAD Dog cases myself. I hope this helps you.
George
Jul 15, 2008 | Western Digital 500GB My Book World...
Acces denied
If you have linux experience and are up for a bit of hacking, here is a solution to your problem:
http://mybookworld.wikidot.com/forum/t-55527/large-file-copy-problem-solved
I bought a 1Tb MyBook World Edition, and it was little better than a doorstop because of the "Access Denied" bug. However, now it runs like a dream.
More things you can do with a MyBook:
http://mybookworld.wikidot.com/start
Far far better than WD Technical Support.
May 18, 2008 | Western Digital 500GB My Book World...
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
732 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
