Question about Dell OptiPlex GX260 PC Desktop
Hard drive problems with Optiplex GX260
I have an Optiplex GX260 that I took out a bad Maxtor hard dirve and replaced it with a Western Digital hard drive and it goes to a black screen with choices of F1 or F2. When I go into the BIOS I find that the computer shows "uknown device" for the hard drive.
  • dluthy Dec 22, 2008
    What perameters are you talking about?
    Master:
  • 413 Answers
You should be able to manually enter the drive perameters into bios. That should let you boot. Or boot it up with a boot disk.
Posted on Dec 22, 2008
  • Dan rogers
    Dan rogers Dec 22, 2008
    sorry kinda got messed up. First is it SETA or IDE? If seta the drive is bad or the controller is bad, With IDE you are lookin at the same kinda problems but if IDE you used to be able to imput the size,heads,allocation etc... Not sure if you can still do that but most likely if you are replacing a drive you think went out i would guess it is the controller on the motherboard.
Hi i have this "Western Digital WD Passport 250GB Portable" Problem Now! broken one of that pin where usb connect to hard dirve .
I did this once had to solder an interconnect to the other side of the connection of the PCB then use a small croc clip to make the other connection worked just fine just not aesthetic
Mar 21, 2010 | Western Digital WD Passport 250GB Portable...
My computer cannot find new hard drive disk . my hdd is western 80 ide
Make sure that the IDE channel you are using is turned on in the BIOS. In the optipled line, you press either delete or F2 to enter the bios when the computer is first powered on. If you're adding a HDD, the bios must be set to look for the hard drive. If you're replacing the hard drive, let the BIOS recognize the drive - save the changes and then reboot.
Jan 22, 2010 | Dell OptiPlex GX260 PC Desktop
I have bought Western Digital 1TB external hard drive. but my window xp is not finding that hard dirve. how can i conect and find on my xp.
You will probably need to install the drivers that came with the drive for Windows to see it. Check out the instructions that came with the unit and it will walk you through installing drivers and connecting the drive to your computer.
Jan 06, 2010 | Western Digital MY BOOK HOME 1TB EXT...
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Computer does not see hard drive or cd rom
Use separate cable for both the hard drive.
Make master to the one which is bootable,restart your system and just check bios setting whether both the hard disk are detected or not..also under boot device check first boot drive is hard drive which is master and bootable..
Jul 21, 2008 | Dell OptiPlex GX260 PC Desktop
My Book chatter
well interanl hard drive are going bad from back sectores u can do low level format on these with a tool suware from makers use windows slow format not quick to help or defrag them all that is just a reg hard dirve in there ok u can change it also reg style desktop hard drive ok
Feb 05, 2008 | Western Digital 320GB MyBook External USB...
Again reloading(restarts)
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Microsoft Windows XP Professional With...
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Dell OptiPlex GX260 PC Desktop Logo
266 people viewed this question
Alun Cox
