Question about Evesham Nav-Cam 7700 GPS Receiver
Nav-cam 7500, gps signal poor and takes up to 30 mins to respond.
Then losses signal every few minutes. Is the external antenna socket an MMCX.
Thanks Charlie
Overcome the problem, bought an external arial (magnetic). Bought it on E Bay for a couple of pounds. You have to put it on roof when travelling it works great, socket is mmcx.
Charlie
Posted on Jan 16, 2009
Hds 10 gen 2 having trouble picking up location takes 20 to 30 minute to locate.
Aluminum will block a GPS signal, but the aluminum needs to be above the antenna and within approximately 12 inches or less.
the other major source of interference is the electromagnetic field of other electronics in close proximity to your GPS antenna. Typically within about 24"-30" or less in distance from the antenna. The internal antenna of the HD 10 is top dead center of the unit.
Turn the "WAAS" off on your unit and see if that improves reception.
Hope this info helps.
May 11, 2015 | Lowrance Hds-10 Gen 2 Combo
What fitting is the external antenna is it mmxc?
I hope everybody visiting this webpage will find this answer useful.
First of all, ignore the antenna connector recommended within the RAC Sat Nav 200 manual, it's wrong.
What you need is the :
GPS Antenna 1M Length MMCX with a
180 degrees straight connector.
Make sure it's a MMCX straight connector.
Plug in the antenna and within half a minute of typing your postcode destination into the Sat Nav the reception will have been picked up.
Hope this saves everybody a lot of hassle.
David Coggon - Author of Children's Book ` Jack's Crayons '
http://www.ahstockwell.co.uk
Aug 04, 2009 | SNK RAC SAT NAV 200 GPS Receiver
My tom tom signal keeps dropping out for hours
ok my aussie compatriot your problem is mainly the battery not being fully charged on the ac charger, it also needs a clear view of the sky. most tomtoms have an external antenna port mmcx but dont buy thoise cheap 28db units as they are trouble, go to Marbella Australia and get one of their 50Db external mouse antennas and that will help
tremendously. Perhaps dump your tomtom while your at it as they are nothing but trouble. just check the numer of issue son this forum.
check out the A8010 or the super A860 on the marbella site then sell off your tomtom
Jun 20, 2009 | Tomtom ONE 3rd Edition GPS
No gps signal
Is the Flip-Up antenna UP? Can the unit 'see' the Sky? - Most only work near the front windshield.poorly everywhere else in the car. The layers of car metal blocks or attenuates (cuts down/reduces) the satellite signals. Also, there might be a MENU option to enable/disable GPS. If you get no joy, could be the connection to the antenna is bad/broken. If all else fails, look for a tiny hole somewhere on the outside of the case and press into it gently with apaperclip. Good Luck
Jan 15, 2009 | Evesham Nav-Cam 7700 GPS Receiver
NAV-CAM 7500
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution...
Dec 30, 2008 | Evesham Nav-Cam 7700 GPS Receiver
NAV-CAM 7500
hi mate the nav-cam 7000 and the 7500 are the same, i have the 7500 all of the data on the disc applies for the 7000 & the 7500 as far as camera updtes this is now in the process with the company that has taken over evesham, anyway you have to install active sync and use the cable to install the info onto the sd card, give it time and you should receive the sat signal unless it is stolen where then they can switch them off. good luck
Aug 30, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Evesham Nav-Cam 7000/7500
May 11, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Nav-cam 7700
A few options:
1. (if new / first time) fully charge - take awhile like 8 hrs or something like that - then let it sit for 15-30 mins. That is how long mine took
2. soft reset (then do #1 again) - the "button"
3. hard reset (then do #1 again) - the "switch"
4. check whether port / baud rate settings are correct (on mine, there seems to be a "hidden" button above "test"
May 07, 2008 | Evesham Nav-Cam 7700 GPS Receiver
GPS Antenna
hi
the 8400 does list an antenna accessory but no socket type
there is also a speaker/headphone out socket
are u sure you are not confused
mmcx and larger mcx are common types
http://en.wikipedia.org/wiki/MCX_connector
GSN 8400 manual here
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/GNS8400_OM_ForWeb.pdf
D
Nov 04, 2007 | GPSRD Radar Detector
Evesham Nav-Cam 7700 GPS Receiver Logo
77 people viewed this question
Top Evesham GPS Experts
Jerry Greenberg
Jerry Greenberg
Illimar Saatvali
Illimar Saatvali
todd
Are you an Evesham GPS Expert? Answer questions, earn points and help others
