Question about Kenmore Elite 45986 Front Load Washer
Kenmoore Elite Quiet Pak 2 HE3 (45862) Control Light Locked on
Suddenly we noticed our Control Lock light went on last night after a load and will not go out. Door unlocks and opens fine but no functions. Unplugging etc. did not help. assume we ahve a bad sensor or switch somewhere but not sure (of course 2 months out of warranty)
  • 1,031 Answers
To disable the control lock, hold the OPTIONS and SELECT buttons at the same time until the control lock light turns off.hope this helps
Posted on Dec 24, 2008
  • 3,037 Answers
Hello anton43
There's a button on the panel, bottom left, which has small print under it with instructions to press and hold three seconds to unlock the controls. Let me know if you have any further questions. Have a Merry Christmas.
bestdarngood
    Sergeant:
  • 306 Answers
There's a button on the panel, bottom left, which has small print under it with instructions to press and hold three seconds to unlock the controls. try tis.. hope tis helps..
    Sergeant:
    Novelist:
  • 327 Answers
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of things you can try:
  • check/reset the circuit breakers or plug in another machine to the same outlet to determine if there is power;
  • reset the machine by unplugging from the mains for an extended period of time not only a couple of minutes;
  • check the door switch (internally);
  • check the drain system. Clean filter, sump, impeller, pump, hose;
  • dry the bottom area (drainage), use a can of compressed air, a compressor, a vacuum/blower or air dry (longer).
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 25, 2008
  • Louie  Role
    Louie Role Dec 31, 2008
    Hi again,
    Any updates or developments?
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
Control Lock
The following link explains how to clear a control panel lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Hopefully this is just a simple matter of operator intervention. If this does not correct the problem, please let me know. I hope this helps you.
Jul 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite smart Wash quiet pak 9 has got the control panel set to lock mode. How can we open it?
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Apr 12, 2009 | Washing Machines
The control locked light is on and can't start the machine
Power shd be on, try to hold down 'end of cycle' button for 3 seconds, try door after a minute or after hearing a click. IF NOT:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Apr 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
KENMORE ELITE PROBLEM
Press and hold the control lock button down until the light goes off. This is a child proof feature that may have come on if you leaned against it to long. After lock light goes off you can use the machine.
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
102 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
