Question about Kenmore 62602 Electric Dryer
HEAT When I am drying it will only stay hot for min, than will only stay warm during the rest of the time and takes hours to dry.
  • Kenmore Master
  • 8,220 Answers
Clean out your vent and filter housing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Dryer heats up but takes 2 hours to dry a load of laundry.just gets warm not hot.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 04, 2010 | Samsung DV306LEW Electric Dryer
My kenmore 90 series dryer takes two hours to dry a medium load. it gets warm but not very hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Kenmore Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
Dishwater completes cycle but there is very little heat .
Actually these elements do stay warm to hot during wash to help in increasing the temp of the water...but more so during drying....how ever they do not get very hot as this would be a hazard..not like a stove or anything (as I am sure you know).....but over time the elements get old and do not conduct (or actually inhibit the flow ..{resistance causes temp increase}, of electricity) the only way to tell is an ohm meter check and removing all wires connected to the same...you would also need the Name brand of the element as well as the model # or part # to determine what the ohms should be...if it is defective you will need to change it out...pretty easy job for anyone handy enough ...
Hope this helps....The Fang
Mar 27, 2009 | Dishwashers
Taking 2 and 1/2 hours to dry a load
I too had this problem. My light still stays on. As for the dry time it was because of a very clogged vent. Test by taking off the vent and trying to dry,just make sure you have air flow or else the fumes will get to you. if it dries quicker its your duct work. do not do it with the open vent against the wall
Mar 25, 2009 | LG DLE5977 Electric Dryer
Nintendo ds
take it apart and clean every bit of water out of it with kitchen roll, any standing water left inside will cause rust. Take the battery out while it dries too (leave it for 3 days in a dry place). Do not try to heat the battery, they explode if heated. Put the rest of the console in a dry warm place. It cant hurt to put it on a radiator for a couple of hours to speed this up.
It may start to work again when it's totally dry (3 days) but its a long shot.
Nov 06, 2008 | Nintendo DS Lite Console
Heating element
this could be a partial faulty heater element, a 2 heat element could only be working on 1 element, this can overload the other one causing it to keep switching on and off at the thermostat, sometimes this can be normal but saying as you think its not hot enough, check you have the settings correct on the heater options, i have seen stranger things happen test element contacts for both circuits unplug machine first
Sep 27, 2007 | Hotpoint TDL14 Electric Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
