Question about Dryers
I have a Kenmore gas dryer 90 seriers, and when I dry clothes it will only get hot for about min, than stays warm durning the period of the drying cycle, what is wrong and how do I fix it. Model#76902692-76902 sn#MH3520698
  • Dryers Master
  • 8,220 Answers
The problem is with the gas assembly coils. They get hot and quit. Then later on they cool off and will work a little bit. Making it an agrevating intermittant problem. These are only 20 bucks and easy to replace:I have a Kenmore gas - c433b30.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
Heat does not go on and stay on clothes tumble but are still damp they never completely dry in 70 min.
sounds like a venting problem, check vent tube for restrictions, you can take the tube off and run the dryer, should have hot air blowing out, if you do then it is the vent tube if not then you will have to clean the inside of the dry out with a vacuum. Good Luck Tim
Oct 25, 2010 | Kenmore 73952 Gas Dryer
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
How Hot Should The Air Comming Out Of My Dryer Vent Tube Be ? I Put A Termastate In Front Of It, And It got Up To 90 Degrees. Is This Too Cold, To Hot, Or Normal ? My Towels Seem To Take A Long Time To...
It depends on how long the vent run is. If you were to measure at the dryer outlet it would read over two hundred degrees. If the air flow is weak, it menas that your vent is restricted and thus causing long dry times.
Apr 06, 2009 | Kenmore 75962 Gas Dryer
HEAT
Clean out your vent and filter housing.
Dec 22, 2008 | Kenmore 62602 Electric Dryer
Dryer warm but not hot takes for ever to dry cloths
Bad blower wheel.
Blocked vent.
Lint ball in filter housing.
All of the above.
Dec 17, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
167 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
