Question about Pioneer PRO-99 TV
It cut off and won't cut back on.
Pro-99 refrence projection monitor reciver. It cut off in the middle of a movie. Prior to it cutting off it was making a faint chirping sound. The sound got more frequent, then the picture went dead. The standby light remains on, but it will not turn on. If I hold the main power button in, it makes a few loud chirps then clicks off back into standby mode. Any assistance would be greatly appericated.
snakehead
  • 1074 Answers
SOURCE: Pioneer PRO-510HD Elite
since your tv is 6yrs old it could be that the video circuit has cold solder that needs to be resolder if that does not work then a focus on the video circuit by replacing the component there, it could be an ic or transistors or diode.if you are not a tech get one to look at your set.good luck.for further help email me at nicodhem@yahoo.com
Posted on Apr 06, 2007
MrBob84
  • 90 Answers
SOURCE: PRO-510HDTV
The intermittencies you mention are common on this
series. The PS - power supply - board needs a
virtually complete resolder op, as the solder used in
that run of units was weak and thin. It will not get
better on its own, any more than needed dental work
will.
Send it to me and I will resolder it and send it back.
I have done so on a number of PS boards in this series,
and am running at 100% success on saving the
510/610/710 series of Pioneer Elites when all they need
is the resoldering op. There is a procedure to follow,
so contact me directly.
www.imageperfection.com
510-278-4247
Mr Bob
Posted on Feb 07, 2008
charcois
  • 763 Answers
SOURCE: problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
Posted on Aug 21, 2008
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Posted on Sep 07, 2008
SOURCE: Power
same problem here
Posted on Sep 25, 2008
Tip
AVCHD to FCP X-MTS/M2TS in 50/60 Progressive mode to FCP X for ProRes 422 (HQ)
HD Videos to Final Cut Pro X-Convert 1920x1080p 50/60 AVCHD files to ProRes for Final Cut Pro X Editing <br />Final Cut Pro X and AVCHD-Import 1080 60p HD Videos to ProRes FCP X Conversion <br /><br />The new Sony camcorders like Handycam HDR-CX360VE, CX700V, and Panasonic camcorders like HDC-TM900/HS900/SD900, TM700/HS700/SD700 support recording in 1920x1080/50p mode for PAL regions like UK, France, German, or 1920x1080/60p mode for NTSC regions like US, Canada. Even though <b>Final Cut Pro X</b> with the new UI is said to support AVCHD files natively, without transcoding to Apple ProRes, the 1920x1080p 50/60 AVCHD files still could not be detected/imported to FCP X. <br /><br />To edit the 1080/60p or 1080/50p <b>Camcorder AVCHD Videos to Final Cut Pro X</b>, the conversion from MTS/M2TS in 50/60 <b><a href="http://www.aunsoft.com/final-mate-mac/">Progressive mode to FCP X ProRes 422 (HQ)</a></b> or to Apple ProRes 422 is necessary. Aunsoft Final Mate for Mac is the recommended AVCHD to ProRes converter for Final Cut Pro X. It keeps better color than compressor. What's more, it can keep 50fps and 60fps in Apple ProRes. <br /><br />The guide below shows you how to <b><a href="http://1080p-converter.com/2011/07/avchd-to-fcp-x-mtsm2ts-in-5060-progressive-mode-to-fcp-x-for-prores-422-hq/">Convert and Edit 1920x1080p 50/60 AVCHD files to ProRes in Final Cut Pro X</a></b>. <br /><br />Step 1. <b>Import 1920x1080p 50/60 AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Run Final Mate for Mac as the best <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Cut Pro X and AVCHD</a></b>, which can import files from AVCHD camera and the separate .mts files on Mac hard drive. For files from camera, just use USB cable to connect camera to Mac, and you can select files to download to Final Mate for Mac with the wizard. Otherwise, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips. <br /><br />Step 2. Choose <b>AVCHD files to FCP X ProRes conversion</b>. <br />Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab to create movie for conversion. You can choose the files to be joined as a movie, or create single movie for each file. In terms of joining as a movie, the files would play seamlessly. <br /> <br /><b>Step 3. Choose Apple ProRes 422 (HQ) with 50fps or 60fsp for FCP X.</b> <br />Click the Export button, and go to the third button for editing software. Choose Final Cut Pro &gt; Apple ProRes 422 (HQ)(*.mov) as the output format. Choose 1920x1080 from the drop-down list of the output video size, and choose 50 or 60 as frame rate according to your camera mode. <br /> <br />Wait for the conversion, and you can then import 1080 60p <b><a href="http://www.aunsoft.com/final-mate-mac/">HD videos to Final Cut Pro X</a></b> through the direct import and enjoy editing in FCP X. <br /><br /><b>Tips:</b> <br />If you face the problem that the resulting ProRes files have no video just sound in FCP X or QuickTime, just make sure you install the related ProRes codec for FCP X, or go to the guide: <b><a href="http://www.aunsoft.com/solve_no_video_problem_after_converting_avchd_to_apple_prores_for_fcp_x/">Solution to ProRes Video Issue in FCP X</a></b> on aunsoft.com.
on Jul 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Import flip video to Final Cut Pro and edit flip video Final Cut Pro Final Cut...
Final Cut Pro is a professional video editing application for Mac users and it is widely used even by many Hollywood people on professional movie post-production. If you are a flip video fan and you want to give professional editing to your flip videos, Final Cut Pro is a great choice. However, Final Cut Pro does not allow raw flip videos to be imported to Final Cut Pro and you will need to convert flip video to Final Cut Pro supported formats. Thus, to edit flip video in Final Cut Pro, you can follow the three parts below:
Part One: Convert flip to Final Cut Pro video
Download Doremisoft Mac Flip Converter and refer to the following steps to import flip video to Final Cut Pro.
Step 1: Add flip videos
Click the "Add File" button to add the flip videos you want to edit in Final Cut Pro to Mac Flip Converter.
Step 2: Select a Final Cut Pro supported output format
Click the Profile drop-up list and select
Step3: Convert flip video to Final Cut Pro
Click the "Start" button on the lower right of the interface to start converting flip video to Final Cut Pro.
Part Two: Import converted videos to Final Cut Pro
Step 1: Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Thenselect one converted file from the Choose a File window and press the "Choose" button to choose this file.
Step 2: Find the file in the resources list for the project.
Step 3: Drag the file into the Timeline and then save the project.
Part Three: Edit flip video in Final Cut Pro
Final Cut Pro is a very professional tool with many functions. The following steps will show you how to use the Timeline:
Step1: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Step2: Add transitions
For flip videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Step3: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
As mentioned above, Final Cut Pro is a very good tool for professionals. If you want to know better about using Final Cut Pro, you can go to certain Final Cut Pro forums. The most popular one is Los Angeles Final Cut Pro User Groupn and you can find a lot of useful info there.
You might also want to buy a book and study how to use Final Cut Pro, such as Apple Pro Training Series: Final Cut Pro 7 and learn how to professional edit your videos with Final Cut Pro.
If you just want to do some basic editing such as cropping, length trimming and video effect adjustments, you can just use Doremisoft Mac Flip Converter to get the job done by following How to edit flip video with Doremisoft Ma Flip Converter.
on Aug 13, 2010 | Computers & Internet
During a power surge my tv turned off and it wont turn on now at all
i have a rca television and my t.v. just cut off when i was looking at it and , when i tried to cut it back on, there was no sound and no picture and the power button did not want to cut off on it's on i had to unplug it.
May 12, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Tip
How to Export Movie from Final Cut Pro (FCP) to FLV? After editing your own...
After editing your own movies on Final Cut Pro or Final Cut Express, you may want to put them on your website for presenting your introduction or promoting your services/products. For users with the older version of FCP, FCE or iMovie, it is easy to export FLV by choosing File > Export > Using QuickTime Conversion. However, if you could not find Flash FLV as output format from FCP/FCE/iMovie, you may need a FCP to FLV converter to get Flash videos.
Aunsoft Video Converter for Mac is the best FCP to FLV converter for you to handle videos on iMac/MacBook Pro with Snow Leopard or Leopard. The Mac FCP to FLV converter supports loading .3gp, .m4v, .avi, .dv, .flc, .mp4 videos from FCP/FCE/iMovie and converts FCP movies to FLV as short film. Below are the steps to export Final Cut Pro movie to FLV with Aunsoft Video Converter for Mac.
Step 1. Load Final Cut Pro movies to Aunsoft Video Converter for Mac.
After exporting movies from Final Cut Pro, run Aunsoft Video Converter for Mac as the Mac FCP to FLV converter, and click the "Add" button to load FCP short films for conversion.
Step 2. Choose FLV output format.
Click the "Format" option and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. This format is compatible to most machines.
Step 3. Transcode FCP movies to FLV.
Click the "Convert" button under the preview window, and the Mac FCP to FLV converter starts converting Final Cut Pro movies to FLV for playing on webpage.
Tips:
1. After converting Final Cut Pro movies to FLV, you need Flash players to navigate the video playback on webpage. You can use free web players like JW player, Moyea PlayBox player and Flow player to present your short films on website.
2. You can set the video resolution of the FLV videos by clicking the "Settings" before conversion.
3. The above step-by-step guide with Aunsoft Video Converter for Mac also works for the movies exported from Final Cut Express and iMovie. In other words, you can also convert FCE movies to FLV, iMovie videos to FLV on Mac OS X.
on Jul 22, 2010 | Cell Phones
Tip
Flash video from Fianl Cut Pro, FCP export Flash video for the web FLV SWF
If you have installed Macromedia Flash 8 in your mac, you will have an FLV video exporter into Final Cut's QuickTime conversion menu and then you are able to directly export Flash video(FLV files) from FCP. However, Flash 8 might not be the right option for you for its expensive or it can't assist you to export SWF file. Then you have a suitable choice, that is, FCP to Flash(FLV/SWF) converter.
With FCP to FLV/SWF(Flash) converter, you are able to convert a movie created in Final Cut Pro to Flash FLV/SWF or generate a HTML web page embedded with skinning and customize Flash player with a few mouse clicks after you export movie from Final Cut Pro as QuickTime movie. This workaround is simple-to-use yet professional, suitable for both beginner and experienced mac users.
Step1. Export Video from Final Cut Pro
After editing video with FCP, Use File > Export > Quicktime Movie to export video from Final Cut Pro. And its exported video is in the MOV format.
Step2. Launch the FCP to Flash converter and add FCP movie
Double click its item to launch FCP to Flash converter and click "Add Video" button to import FCP movies.
Step3. Choose the output quality
Click the "Customize" button and in the "Profile" field, then according to your requirement, choose the output quality: F4V, High quality, Low quality, Normal quality or Custom.
Step4. Start FCP to Flash conversion
You just need to click the "Start" button and the FCP to Flash conversion will start automatically.
About Final Cut Pro
Final Cut Pro shorting for FCP, is a professional video editing software program developed by Apple Inc for mac users, which offers pro-level editing for people who had hit iMovie's ceiling and wanted more editing control and options. As part of the Final Cut Studio, Final Cut Pro allows video editing for highest-possible quality and mix frame sizes, frame rates and formats in the same Timeline in real time.
Next: 8 Tips for create FLV/SWF/HTML web video(Part I).
on Jun 22, 2010 | Computers & Internet
CUT OFF TO STANBY
See Speargunner Oct.26,2007.................................T.
Jan 08, 2007 | Pioneer PRO-99 TV
Tip
FCE to FLV/SWF converter, embed FCE project in webpage
One friend of mine is using Final Cut Express to edit your film footage and the final film will be uploaded to your website for viewing. He need to get the videos to FLV format for easily web viewing. Unfortunately, FCE doesn't export to FLV. Do you have this problem with my friends?
My advice is to use FCE to Flash converter. The FCE to FLV converter can meet your need to convert FCE exported movie to FLV/SWF and generate a HTML web page embedded with flash player so that you can easily upload movie exported from Final Cut Express to Youtube and insert your masterpiece created in FCE to your website.
Step1. Export Video from Final Cut Express
Export video from Final Cut Express. And the exported video is in the MOV format.
Step2. Launch the FCE to Flash converter
After download the FCE to Flash converter, double click its item to launch it. The interface is user-friendly, look like this:
Step3.add MOV files exported from FCE
Press "Add Video" button on the top of the interface and browse the pop-up directory, choose all mov files exported from FCE to import into the converter.
Step4. Add effect
Hit the "Effect" tab. Select a cool special effect for you flash.
Step5. Start FCE to Flash conversion
You just need to click the "Start" button and the FCE to Flash conversion will start automatically.
Knowledge on Final Cut Express
Final Cut Express(FCE) is a powerful and extensible video editing software designed by Apple Inc. The supported video formats by FCE is DV, HDV and AVCHD. The special feature is its ability to import iMovie 08 projects and use iMovie as a video library. Among three distinct tiers of video-editing software Apple offered (iMovie, FCE, FCP), iMovie catered to beginners, Final Cut Express mid-level video editing fans and Final Cut Pro pro-level editing people.
Next: How to convert videos to Flash, SWF, FLV on mac with video to Flash/FLV/SWF converter for mac.
Televison & Video Logo
61 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
