Question about Mitsubishi WD-60735 Projection Television
I have a model WD-60735 DLP HDTV. My DVD player is not playing. I have three plugs coming out of the DVD player, two audio and one video. I have tried plugging them into the audio/video plugs in both Input 1 and Input 2. DVD is showing as as an input device in the input function and everything seems to be OK from that perspective, but no picture and no sound.
  • 1 more comment
  • Drew
    Drew May 11, 2010
    Also, the three plugs you mentioned coming out of the DVD player...Where do those come from....reply with the names of each...
  • Drew
    Drew May 11, 2010
    What happens when you turn the TV on Input 1 and then turn on the DVD player....do not put anything in the player, just turn it on with the TV on INPUT 1. And then do the same thing for input 2...reply with what happened on both inputs...
  • miguel_varga May 11, 2010
    So the TV recognized the input?
    And you selected DVD as the input device?
    Even after that the TV shows no picture when playing the DVD?
    And No sound.
    Have you canceled out the possibility of the DVD being bad?
    Have you selected the correct audio setting?
    Problem Solver:
  • 10 Answers
Either your cable or your dvd player. Have you tried it on another tv to make sure its working?
Posted on Mar 03, 2009
  • Drew
    Drew Mar 03, 2009
    let me know
Tv won't power on anymore. i get a solid red light. why?
Solid red light means the lamp has failed. Try replacing the lamp first. Mitsubishi DLP TV Bulbs
These folks have the proper lamp you need and have a 6 month warranty
Sep 16, 2015 | Mitsubishi WD-60735 60" DLP HDTV
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
How to conect dvd player to my mitsubishi tv model WD-52525
You have several options with your TV depending on your DVD player. The best quality video will be achieved with an HDMI cable if your DVD player has an HDMI output. Next best would be to use a component video connection which consists of 3 RCA cables for video and two for audio. The third option is S video (round connector with pins inside)
Dec 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
Jul 15, 2009 | Mitsubishi WD-60735 Projection Television
Mirror on Mitsubishi DLP HDTV 60" model # 60735 dirty looks like black blade of grass on main screen how do i clean the mirror
Hello zero_x08, 1) remove the cover of the TV and find the light engine. 2) using canned air blow dust from the mirro assembly 3) test the screen by turning the TV on after the system has warmed back to room tempurature. This should clean the mirror Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Mitsubishi WD-60735 Projection Television
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
