Question about Canon S520 InkJet Photo Printer
Little or no ink on the paper
The colours of my prints have become very bad over some months of printing. Now it even doesn't print black anymore.
I ordered deep-cleaning serveral times and cleaned the printhead with pure alcohol. But ... that was not the solution.
  • schoenms Dec 22, 2008
    Of course not. That's the first thing to do! I put in brand new ink cartridges.
    Guru:
  • 449 Answers
Check your ink cartridge ink is probable dried up or it's finish.
Posted on Dec 22, 2008
  • Jerry Parmanand Dec 22, 2008
    Sorry try this,
    Solution: This can happen if the cartridge was allowed to dry out before refilling. There is something you can try, however. Place the cartridge print head in a shallow dish of warm water or on a warm, wetted paper towel. Allow the cartridge to sit for as long as necessary. You will begin to see ink flowing or seeping out of the cartridge once the dried ink starts to disappear. You can also try using a cotton swab soaked in rubbing alcohol to clean this area. After this, dry the external areas of the cartridge and reinstall it in your printer. Run your head cleaning utility, always following the instructions in your printer manual. happy holiday
Get the esp 2170 to not print light green instead of black ? I keep on replacing cartridge , to no avail !
replacing a cartridge, while the nozzles are blocked won't help.
Realise the printer will mix there colours to get "black" on the paper. So even a full cartridge, can't make the other colours black till the blockage is gone.
Please try this. If you have ink cleaning fluid, (only for printer ink) use that, if you dont have cleaning fluid, use clean water.
Open the printer as if you replace a cartridge. Remove the black one and look tot the bottom of the cartridge holder. There is a little pipe, where the ink should go in. put some drops water or cleaning fluid in there leave it a few minutes. with a tissue dry it and again insert some drops of water or cleaning fluid. Then put in a cartridge and give the printer a black and white print job. Like print a few A4 papers. Let it print till the black comes back. Can take up to 4 pages A4. I hope this will unblock the nozzles.
Please even if you don't need to print, switch the printer on at least once a week. And even better, let it do a bit of printing every week. This will save a lot of frustration.
Dec 03, 2014 | Kodak ESP Office Equipment & Supplies
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Faulty Ink Cartridge?
You can try this, but maybe a new print head is needed.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 28, 2008 | Canon i475 InkJet Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Canon S520 InkJet Photo Printer Logo
88 people viewed this question
Clive
Clive
old marine
old marine
