Question about LG WM-3677HW Front Load Washer / Dryer
LG WM3677HW Pump Problem
I have been receiving OE errors and more pump noise than normal (sounds like grinding) lately and the clothes are not getting anywhere near dry. There have been a few times where there was lots of water left in the drum and the washer stops and then gives an OE error. I have cleaned the trap several times and but cannot seem to get it working this time.
I would prefer not to call a service tech as I should be able to handle the repair job of replacing the pump(s) but don't know the best way to get at them. How can I tell which one to replace or should I just do both of them?
Thanks for your help.
  • 2 more comments
  • Michael Raburn
    Michael Raburn Jan 17, 2009
    I am ahving the same exact problem with my 3677 also. I am not appliance tech. but I can usually figure it out with a little boost in the right direction. THANKS Michael
  • Anonymous Mar 27, 2009
    yes
  • paulmn Apr 27, 2009
    I also hear a grinding sound and sometimes the drum is full of water. I would love if someone could tell me what I need to do to fix this! thanks!
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Sorry for not getting back to you. I have not been getting my "Ask Me" questions forwarded from Fix-Ya. Let me know with a comment if you still need help with this issue.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
No need to go in through the top to remove the pump on a WM3677... i've removed mine seems-like a dozen times already, and will soon replace it.
Be sure all the water is out of the washer before starting.
We have a training problem with not cleaning the lint trap, and the pump gets jammed. The design is bad; it traps some REALLY nasty gunk underneath the impeller (in the cavity).
Anyhow, when facing the machine, put a low step-stool to the right of the washer and (carefully!) tip it over onto it's side, resting on the stool. Pad the stool with a towel, if you're careful.
The pump is in the bottom of the machine, towards the front/face on the now-higher side. That's the left, as facing the machine.
First, remove the lint-trap, and the plug in the drain line (small black hose). Remove the access-panel plastic piece, it is held in by one small phillips screw.
Note the 4 wires attached to the pump. Remove them, they are spade-connectors. Note the color/position if you like, but it's not really important.
Reach behind the pump and pull off the small hose. This is the sprayer, and it does not have a clamp on it.
Use large channel-lock pliers to compress/slide back the clamp on the large rubber hose that goes from the drum to the pump. This is the supply/suction side. Remove the hose, but be sure not to dislodge it from the bottom of the drum.
The ribbed hose also has a compression clamp. This is the drain hose.
Remove two of the three phillips screws that hold the pump in, they are under the plastic panel we removed a minute ago, on the front of the machine.
Holding the pump with one hand, remove the last screw. The pump is free.
Assembly is the reverse, and don't forget to put ALL the hoses back!
Posted on Apr 08, 2010
The pump seems to be a weak link as mine failed twice in 4 years (it's the drain pump, not the spray pump by the way). The impeller spins loose from the motor shaft and no longer pumps. The repair requires pulling the top, front and drum seal clamp (that was the toughest part) and r/r the pump. Part cost was about $40. I believe when the lint builds in the trap it causes a vacuum to build on the impeller and drags it loose. Keep a cleaning schedule on the lint plug and that should help.
Posted on May 28, 2009
  • Flim63 Feb 19, 2010
    The grinding noise is the impeller separated from the motor shaft, but it is more likely the drain motor having this problem. I have replaced the drain pump 3 times (including today). My spray tube also gets compacted with lint but the pump has never failed on that. Major weak part in that pump design. LG today said no service recalls or notices on my model!
I just found a way to solve this problem. The drain plug is probably clogged from all th elint that does not have a way out of the system. There is a service panel on the bottom left of the machine. I opened this panel and first gently pulled the black hose out of the clip and drained the extra water into a pan. Once the water was out, I put the plug back in and put it back into position. Next there is a round piece that unscrews to the right. after I unscrewed it there was a lot of trapped lint that I got out of the trap. Next I just screwed it back in and everything worked again.
Posted on Jan 27, 2010
Anyone have step by step instructions for replacing the water pump on an LG front loading washer
Posted on Mar 22, 2010
Hey guys, i have a wd1457rd and the spray pump makes a horrible grinding noise, i have opened it and it was full to the brim with compressed lint, cleaned it, cleaned the pipe that goes to the spray nozzle, it now sprays but the grinding noise is still there, could it be the o-ring around the pump shaft or the shaft it self causing the noise, maybe water or junk getting in between the shaft?
any help would be good, the noise is loud and annoying.
thank you
Posted on Feb 09, 2010
Replace the water pump not hard to do. fit the problem [ pump is no the way ouy ]
Posted on Apr 28, 2009
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 17, 2011 | LG Washing Machines
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
LG WM-3677HW Front Load Washer / Dryer Logo
2,498 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Charles T Nevin
Charles T Nevin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
