Question about Amana ARB2217CSR Bottom Freezer Refrigerator
Amana side by side freezer side not freezing?
Amana Model DRS2462BW, SN 0112161443. Noticed yesterday that frozen items were not frozen anymore. Freezer side holds temp of 31 degrees. The fan in freezer is running when I open the door. The refirgerator side seems to be doing fine, temp stays at 37 degrees.
Is this a fixable probelm? Could it be the auto defrost messing up? Have heard it is possible to bypass auto defrost and freezer will work again? Also, how do I find out if this unit still has any warranty left? Please help !
catriver
  • 878 Answers
SOURCE: Constant freezing up
Doug, This model has an adaptive defrost board. You can put it into a forced defrost through the control panel. Most of the time I have been finding the control board (Jazz) board to be the culprit. To enter into a forced defrost, open the right door only. Hold the light switch down. Press the refrigerator temp down key 3 times. Release the light switch. Display should show Fd. Press the refer temp down key 1 more time to confirm. Toggle between short S and long L defrost by pressing the refer temp up key. For testing, use the L. Press the refer temp down key once more and you are now in defrost. Now, if you want you can peel the freezer back panel off to see if the heater is coming on. With it in forced defrost you should hear sizzling and popping after a while. To get out of the test mode, just close both doors. The Jazz board, part 12002449, is in line with a defrost bi metal that sits on the evap. If the bi-metal is bulged, that could be the problem. Like I said earlier, I have found in most cases the Jazz board itself to be the problem. Hope this helps you understand the refer a little better...Catriver.
Posted on Oct 06, 2007
  • 29 Answers
SOURCE: amana drs2462bw, replaced the relay
relay has gone again or compressor has a problem
Posted on Aug 13, 2008
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
landsend
  • 1066 Answers
SOURCE: Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Posted on Mar 22, 2009
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
The freezer is not working properly. Measured temp at almost 40 deg. Have cleaned coils and vacumned fan grill. Some items are frozen, but newly added do not freeze.
Check for any frost on the inside, probably the back, of the freezer compartment. If there is any, either the defrost heater, defrost timer or defrost termination thermostat is bad. Need your model # to continue.
Mar 03, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Amana ARB2217CSR Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
