You must set your MTU in your modem/router just login to it and search for it in the configuration menu.
Usually you have to set it to 1492 though so if you should have set the MTU to 1364 already and it didnt work try this one as well.
For cable and DSL modems you should set it to 1492 in general as well for a proper connection.
The MTU is the maximum size that an IP-packet that is transfered across the internet may have just for general information.
I hope this helps.
Kind regards,
[email protected]
SOURCE: xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
SOURCE: XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
The MTU of your router or gateway must be greater than or equal to 1365. If it is less than 1365, you won’t be able to connect to Xbox Live.
I have the same problem. every time i try to connect it says my MTU setting has to be set to 1364. HOW DO YOU SET YOUR MTU.
How do i log on to my MTU then?
what should i set it to
