I also found this video...
And on the Whirlpool site using the other model number I found the owners manual but that was not very helpful
https://www.whirlpoolparts.com/UserManual/5edfbda346524f8c85250e3217c85a1b/Whirlpool-Refrigerator-Repair-Manual-GI0FSAXVA01-GI0FSAXVB01-GI0FSAXVB02-GI0FSAXVQ01-GI0FSAXVY01-GI0FSAXVY02-GI5FSAXVY01-GI5FSAXVY02-GI5FVAXVB02-GI5FVAXVL01
Good luck on your troubleshooting...
I SUGGEST YOU CONTACT THE MAKER, AS ANY TIME YOU MESS WITH IT, THE WARRANY IS VOID.
IT IS TOO NEW TO DO YOUR OWN REPAIRS.
HAVE THEM GIVE YOU A SHIPPING LABLE TO SEND IT BACK TO THE MANUFACTURER FOR A REPLACEMENT.
First make sure the battery is fully charged. Then check for clean battery post connections. Then check all the main fuses located in the plastic box under the hood close to the battery on top of the inner fender. You should have all dash lights if everything check out to this point and it should turn over with the key.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
If the battery is low on charge (but not dead) then the sound should be a fast clicking of the voltage regulator. In this case no power is sent to the starter so the car engine will not turn over. All you hear is the fast click.
You mention a high-pitched quiet buzz sound. All I can think of is the electric fuel pump but that is in the fuel tank. There can be be a whine/buzz when starting the car because the fuel pump needs to pressure up the system. However, if the battery/starter are good then the engine would turn over, but with no fuel...it would not start if the fuel pump is bad.
If the car is a manual...you might try putting it in gear and rocking the car a bit to see if the starter somehow is jammed
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage). If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
what are facing is a problem caused by a virus that either destroys files that support .exe applications to run or it replaces which makes your machine unstable. my first solution to you is to repair your operating system using the operating system cd. secondly, if that doesn't work please try installing a second os on your system and then you do a dual booting. u then delete the folder of the previous os. if that does not work u backup ur files and then you format ur system with a new os
You can check to see if the fuel pump is bad..Remove gas cap and listen into tank while another person turns key on.If you here a buzzing noise the fuel pump is most likely OK...If you don't here anything Check owners manual for fuse location and check to see if there are any blown..There is also a fuel relay fuse under the hood
the tv remote wont change channels or go to input...
please help solve this problem A.S.A.P.
