Question about Pearl Raidmax 811 Virgo (RAD811P)
Side fan &front tempnot running
I installed a transfer from old case to virgo 811. the side fan and temp not working, hd light is continuously on (front panel pins possibly not plugged in correctly) HELP!!! it has a thermister double wire ,,, where does this get connected???????????????????
  • Jamey Pat Odau Apr 15, 2007
    Problem solved ,,wrong connection on thermister wire and also side fan &LED Hdd was one pin off. All solved today.
Changed to 4wheel drive low and I can't get it to change back to 2 wheel drive.
1999 Blazer. Thing's to check. 4x4 problem. There's an actuator pump under your battery plate. Make sure its in good shape and its working proper. Next check the cable that runs from the pump to the front transfer case. Then check the actuator switch on the front transfer case. Then check the vacuum lines from the front transfer case to the rear transfer case, that should be right under the drivers side door. There's also a actuator switch on the rear transfer case witch two vacuum lines run out of. Check them also, and last check your fluid level in your transfer case. Start from the beginning to the end. Don't forget to use your 4x4 every know and then to keep it up to power. Its not like the good old days. Where a pull of the lever on the floor engaged the 4x4. I hope this helps.
Apr 09, 2014 | 1999 Chevrolet Blazer
Whirlpool side by side not cooling
The round object is the compressor. Is it running continuously, or is it clicking on and off every 2 or 3 minutes? There also should be a fan beside compressor. Is it running? Also check Fan in freezer to see if it is running. Is there any frost build up on inside back freezer wall? If fans are working and compressor is running continuously and there is no frost buildup in freezer, then you most likely have a sealed system problem meaning its low on freon or there is a blockage in system.
Oct 31, 2017 | Whirlpool Refrigerators
Fan issue with hd-52g787 52 inch
The lamp is protected if fan does not work it has a thermal fuse that will cut power to lamp etc.
One of the real issues is the fans intake air from front of set and exhaust it out rear---sets and fans get coated with fine dust and cause problems including in some cases set shutting off.
Apr 29, 2012 | JVC HD-52G787 52" Projection Television
Purchased 2006. Ceiling mounted. Just stared overheating after approx 10 minutes after last bulb replacement in March of 2010. Floor fan pointed at projector helps. Tried cleaning. Running right side...
Yes, if bulb was low price and was installed in old lamp casing then it is bulb that is not good and creating too much heat that exhaust fan can't throw out to make projector cool enough so temp sensor activates and send over heat signal to system control chip thus projector shuts down.
Please install original lamp that comes with casing to solve this issue.
If lamp was original then check exhaust fan that might be running slowly due to stiffness in bearing so temp sensor finds over temp in projector.
Hope these info will help you.
Thanks.
Dec 18, 2010 | Optoma EP1690 DLP Projector
I have a Kenmore side by side refrigerator freezer and the fan will not stop running. The refrigerator is cooling fine but the fan is running continuously.
The fan must run otherwise the temp. cant be correctly distributed. If temp. is correct, leave alone. If temp. to cold, turn it down untill correct. Fan will very possibly switch off then.
Sep 24, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
TEMP DISPLAY AND FAN NOT WORKING
i have the same problem--i havent replaced the fan--but was considering the control board--have you replaced or cheked this yet?
Aug 01, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
Transfer case removal and installation
   You need to remove the skid plate/crossmember (6 3/4 bolts at the frame and 3 nuts at the trans mount.). Support the trans first with a jack and a block of wood before removing. Remove the rear drive shaft from the differential and pull it out of the transfer case. Unbolt the front shaft from the transfer case only and wire to the side with a coat hanger.Disconnect the vacuum connector from the top and the speedo cable. Unbolt the shifter and bracket (tricky operation). unbolt the transfer case from the trans and pry it rearward with a floor jack under it. Reverse operation to install. The 87 used a different case than the 231 from the factory but the 231 will work. You may have a concern with the length of the shift linkage. If you do anyone with a welder can extend it for you. Good luck hope this helps.
Oct 10, 2008 | 1987 Jeep Wrangler
Pearl Raidmax 811 Virgo (RAD811P) Logo
153 people viewed this question
Top Pearl Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Pearl Computer and Internet Expert? Answer questions, earn points and help others
