Question about Dell Inspiron 531S (DDCWGA1_5) PC Desktop
My 21inch Samsung monitor screen keep turning black
HI! My 21inch flat Lcd panel monitor just from yesterday started turn off,I've tried to turn it off completely and turned it back on and it stays 3-4 seconds on ,then again becomes black as if it is off.I've tried to fix by pressing auto adjust but it didn't help.Checked all the connected wires and they were fine.Monitor light is on,but the screen is completely black and no sound at all.Please, help me to fix it.
  • jozzle Jan 05, 2009
    im having the exact same problem! i found slammin it helps but will most probably end up breaking it! can u suggest anything?
  • 26 Answers
Try another monitor to make sure that the problem is not as a result of there being no output from the system unit
Posted on Dec 22, 2008
My Monitor LG Flatron W2243S keeps flickering and turns off, this started yesterday
Try another good monitor, if it solves the problem replace the monitor if not replace the computer.
Oct 25, 2012 | LG Flatron W2243SPF Widescreen LCD Monitor
Technika 32-270 LCD TV won't stop scanning
Need help stopping scan on tv, won't turn on and no remote will activate anything on the monitor. Help flat screen tv.sanyo keeps on percenting
Dec 31, 2011 | Televison & Video
I have a Samsung 52 LCD TV about 2-1/2 years old. Start clicking about 10-12 times then it turns on. today I turn it on and it just keeps clicking and will not turn on? any Ideas.
The power supply board it is dying and most likely causes by weak and dying capacitors parts bulges up or puffing up leaking.The power supply board,that the board where the power a/c cord plug into it.U have all the tools,understanding basic electronic also can do basic soldering work?Yes check the power supply board carefully replaced all dying to be dead capacitors parts or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 25, 2011 | Samsung LN55B650 55 in. LCD HDTV
Yesterday turned on all I get is a black screen,
Sounds like it may be the backlight inverter. Have you disconnected from the mains when you turned it off? leave it for 24 hrs then re-connect. this should be covered if you have a warranty
Jun 16, 2010 | Samsung LA40R81BDX 40 in. LCD TV
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Gateway flat screen monitor goes black when turned on
open monitor and look at the PC Board to locate some kind of DRY SOLDER or burn point , specially where a transformer is located , check re solder any solder point that looks suspicious , and try again , hope this helps
May 03, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again,...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Mar 19, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Dell Inspiron 531S (DDCWGA1_5) PC Desktop Logo
103 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
