Question about Brother DCP-110C All-In-One InkJet Printer
Colors problem Hello, i have a following problem: two of four colors are missed on the printings. When i print color test page the magenta and blue patterns are printed partially. I tried to clean the color nozzles with the internal utility, but it didn't help. I activated it many times, but the patterns are still partial. Is it the hardware problem or some nozzles are still blocked ? Befot that the printer was about 2 monthes without usage.
    Novelist:
    Scholar:
  • 104 Answers
When you don't use your printer for a while the ink in the printheads tend to dry out, causing problems just like this! Some printheads are built into the cartridges others are in the tray that hold that cartridges, i'm not too sure how that specific Brother model printer does it! But what you can do is try cleaning the print head(with the built in utility) several times or take it to someone to service the printer! Trying some new ink cartridges might do the trick! regards, babb
Posted on May 10, 2007
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Mfc 5860 red printing green - already checked print levels. all are fine.
    1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
    a. Press INK.
    b. Press the UP OR DOWN ARROW key to select Test Print.
    c. Press OK.
    d. Use the UP OR DOWN ARROW key to select Print Quality.
    e. Press OK.
    f. Press COLOR START
    The machine will generate the Print Quality Check Sheet.
    2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
    a. Press STOP/EXIT to return to the "Date and Time" display.
    3. Evaluate the Print Quality Check Sheet.
    On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    NOTE: Cyan is the light blue color and magenta is the pinkish color.
    a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
    4. Open the Ink Refill cover.
    5. Open the cartridge covers of the colors that do not appear in the correct order.
    6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
    7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
    a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
    b. Press 7-6, The LCD will display CLEANING ALL
    c. Press 6, the LCD will display eINIT__P ALL
    d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
    e. Press the BLACK START Key.
    • After the machine completes the Setup Purge it will return to the Standby Display.
    8. Print another Print Quality Check Sheet
    a. Press INK.
    c. Press OK.
    e. Press OK.
    9. The machine will generate another Print Quality Check Sheet.
    a. If all four colors printed correctly the issue is resolved.
    b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
    Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
    "Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
    1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
    2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
    3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
    4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
      • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
        c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
      • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
        Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
        Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
        Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
      • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
    Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
    We use HP Color Laserjet CM1017; Magenta color is not printing
    Dirty laser unit - needs (careful) cleaning internally.
    See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
    All the same laser unit
    Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
    ESP9 color prints begin coming out purple like
    Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
    Jan 02, 2010 | Office Equipment & Supplies
    Colour problem
    If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
    Dec 24, 2009 | HP LaserJet 3000n Printer
    Colors are not printing the acutal color
    It all depends on the meaning of 'not properly'.
    Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
    The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
    Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
    Sep 09, 2009 | OKI C5150n Led Printer
    The lt magenta and magenta just quit printing between pages
    1. Check if the cartriges are correctly installed:
    Installing the Ink Cartridges
    2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
    Color Mix or Missing Colors on the Diagnostic Page
    Repeat if needed.
    3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
    Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
    Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Brother mfc 3360 model mostly problem is no printout, pls soluti
    Hi!
    If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may resolve this problem.
    To verify the ink cartridges are installed correctly follow the steps listed below:
    Open the ink cartridge cover and reinstall the ink cartridge. Open each lock release lever and push it until it clicks, and then close the ink cartridge cover.
    The LCD may then display:
    Did you change xxxxxx? Yes No.
    The LCD may display this question for the color(s) that was replaced.
    Select Yes or No by pressing arrow keys or 1/2 or "+/-" key.
    After all the correct selections are made, the machine will then go into a cleaning.
    The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will go back to standby mode automatically. Print the Print Quality Check Sheet and see if all colors are present:
    Press the Ink or Ink Management key.
    Use the up or down navigation key to select Test Print.
    Press OK to confirm your choice.
    Use the up or down navigation key to select Print Quality.
    Press OK to confirm your choice. Press the Color key to print the Test Sheet.
    If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jun 25, 2009 | Brother MFC-3360C InkJet Printer
    Unable to print BLACK
    The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
      1. Press the Ink Management key.
      2. Use the up or down navigation key to select TEST PRINT.
      3. Press Set to confirm your choice.
      4. Use the up or down navigation key to select PRINT QUALITY.
      5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
    If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
    Cleaning the Print Head
    2. Use the up or down navigation key to select CLEANING.
    4. Use the up or down navigation key to select the color that is not printing
      -OR-
      Select ALL if more than one color is not printing.
    5. Press Set to confirm you choice.
    6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
    7. Test by printing the "Print Quality Check Sheet":
    If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
    I hope it helps!!!
    Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
    Brother DCP-110C All-In-One InkJet Printer Logo
    123 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
