Question about Philips Cameras
Philips photo frame model 7FF1, has pictures loaded on it. when turned on, the screen briefly displays loading 1 of 38 pictures and the reverts to a white screen with the philips logo on it and the buttons at the back do nothing
jackboy
  • 2985 Answers
SOURCE: when camera is turned on screen shows no image and "No Image" appears, if a picture is taken screen is totally white, yet camera appears to function.
This is a processor fgailur - Canon Support will adive the best route for this
Posted on Sep 22, 2007
softplanway
  • 53 Answers
SOURCE: philips photo frame
Heyo Nathan
here is the manual http://www.p4c.philips.com/files/7/7ff2fpa_00/7ff2fpa_00_dfu_aen.pdf
and here is the driver software on the Philips site
http://www.p4c.philips.com/na4/7/7ff2fpa_00/7ff2fpa_00_fus_aen.zip
good luck!
Wayne
Posted on Dec 28, 2007
mcomijohns
  • 477 Answers
SOURCE: How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Posted on Feb 20, 2008
  • 3 Answers
SOURCE: White Vignette ('Artistic' white edge) around all photos
I sent my camera back to Fuji and they replaced the CCD free of charge. I had the same problem plus sometimes the pics just came out completely white
Posted on Aug 31, 2008
  • 22 Answers
SOURCE: Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Posted on Sep 09, 2008
Philips Photo Frame Failed to load executable file
Download the last Firmware-File from Philips and extract it. In the extracted folder is a file called execute.bin. This file must be moved over the Micro-USB-cable to the internal root folder. After a restart the photo frame should be automatically install the last firmware.
Dec 02, 2012 | Philips PhotoFrame -10 Digital Picture...
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
Have a new 8 gig memory. Shows full before all pictures load, should have loads of room?
I would format it using your computer, then try loading in your photos again.
In Window, go to your file explorer, right click on the drive and click Format.
http://www.blogsdna.com/wp-content/uploads/2009/01/format-usb-drive.png
It's ok to do a 'quick format'.
This will delete everything on the drive.
Now try loading on your photos, and see if that made a difference.
Mar 07, 2011 | Philips 7FF2CMI/00 Digital Photo Frame
Frozen Screen on Digital Photo Frame
I have the same problem!!!
Did your frame already work?
Feb 15, 2010 | Philips 6.5-Inch Digital Photo Frame...
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
I have a HP df802 series digital picture frame. Using a 2 GB SD card or 2GB USB drive, the browse thumbnail mode only always displays 200 x 8 photos and always the same ones. I have over 2500 photos on the...
I would transfer all the pictures to my computer hard drive and then use another sd card - load some pictures on there and then introduce it to HP - if that also does not work then issue is with the picture frame. If it works then hassle is with original sd card. Sometimes reformatting the sd card will restore it to proper operation. Sometimes it will restore but then revert as my card does all the time since it is a sick puppy!
Aug 26, 2017 | Sunpak (SDPF-070AW-0US) Digital Picture...
Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Dec 19, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Was given digital picture frame . have no cd manual. haS 22 PICTURES ON IT .CAN I PUT MORE? MODEL NO. 7FF1
It depends on how big the existing pictures are. It has a 14MB internal memory, but it says about 12MB for storage. You can buy memory card to insert into the frame but it will not display internal memory once you insert a new memory card. If you bought a 512MB card, you could put hundreds to thousands of pictures in JPG format. You can hook the frame to your computer or directly to a digital camera. From the computer it takes a few seconds to convert the pictures. The frame will show up on your PC as a mass storage device and you will be able to delete photos as well.
I hope this helps
Dec 05, 2008 | Philips Televison & Video
Cameras Logo
96 people viewed this question
Top Philips Cameras Experts
Lyle Siemens
Lyle Siemens
Mohamed Ismail
Mohamed Ismail
Prashant Hattangadi
Level 1 Expert
Are you a Philips Camera Expert? Answer questions, earn points and help others
