Question about Logitech (980240-0403) Microphone
How do i remove the microphone from the base to the monitor mount?
Because the instruction guide, doesen't really give that much detail about anything. and i would really like to know how. i would really appricate it a lot too! thank you guys!
You juspull on it firmly and wiggle slightly. I wasn't so sure but it did not break.
Posted on Sep 19, 2008
How do I remove the base neck from the monitor? I
theres a scre that is making the base stick to the monitor, take it out and slide out the base, or check the user manual for that
Feb 15, 2010 | LG W1934S-BN 19" Monitor
Attaching Samsung 2033 monitor to base
The solution is that you simply have to really force the monitor onto the base post. Thanks anyhow.
Jun 23, 2009 | Samsung 204T 20" LCD Monitor
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
Type and size of screws to attach wall mount to viewsoni 17" lcd
Hi there!
Please refer to Page 7 of your VA1703w user manual for help on mounting this monitor, if you do not have the manual available, you can get it online here:
From what I can tell, you may be re-using the screws that you remove during the listed procedure.
Feb 17, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Dec 04, 2008 | X2Gen Computers & Internet
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
How do I remove the base of a Viewsonic VX900 monitor?
actually you will be having a projection which locks into the slots of the monitor..
you need to apply some pressure to remove them out of the slots
Jun 18, 2008 | ViewSonic VX900 19" LCD Monitor
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Open Questions:
See all Logitech (980240-0403) Microphone Questions
Logitech (980240-0403) Microphone Logo
182 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
