you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
Neff washer/dryer v5340xogb not spinning . Drum will turn slowly and slightly rock when this happens...
(More)
Neff washer/dryer v5340xogb not spinning . Drum will turn slowly and slightly rock when this happens a noise like 'gravel on a tin plate' is heard, please help . karen email karenmiller8la@fsmail.net
Hi. I cant remove the detergent dispenser. I tried to pull it very hard but it never goes out. I...
(More)
Hi. I cant remove the detergent dispenser. I tried to pull it very hard but it never goes out. I want to clean it from detergent build up.
My Neff washer/dryer is flashing Error code 6. Is there a way to manually drain the drum as it is...
(More)
My Neff washer/dryer is flashing Error code 6. Is there a way to manually drain the drum as it is full of washing and water at the moment! Grateful for your advice- thanks!
