Question about Samsung SPH-a800
Phone will not turn on
When you go to turn the phone on all it brings up is the screen with the little ball and under that says sprint.. it just stays there doesnt move.. it will also freeze like this when you go to charge it.. any ways to fix this piece
  • 43 Answers
hi might be this an internal error == did your cell crashed on the floor == or do you checked that your cell is not attacked by any virus ???
Posted on Apr 28, 2007
0 characters
1 Points
How to get my kyocera torque to turn on
Unfortunately the phone is fried. I had this happen to me also. Took it in to a Sprint store and they ordered me a new one at no charge. Kyocera is still working out the bugs on this phone.
Jun 28, 2014 | Kyocera Torque Sprint
LG LS970 wont reset stuck on system screen wont show keyboard
take the battery out of it and start over..
Jan 12, 2014 | Cell Phones
How to do a manual update prl for sprint evo 4g
There are 2 ways you can update your prl's for your sprint evo 4g phone. Both require that the phone is active on the Sprint network. The easiest way is to dial *2 on and hit send. This should bring up the Sprint Zone. The Sprint Zone will run a quick diagnostics on your phones voice and data to make sure it is working. If you scroll down the page on your phone you'll see a section titled "My Device", this section allows you to update your profile and prl's if there is an update available. This section will also show you if the voice and data passed or failed the tests. If you click on update profile of if you see a message that says new prl's are available, click on either one of those and that will update them for you.
The Second option is to do a manual update using the phone settings. From your home screen, push the menu button. Select "Settings". Scroll down and push "Update Phone". You will see an option "Update PRL's", push this and follow any instructions it gives you. Once the update is complete, you can return back to the home screen and use your phone as normal.
Aug 29, 2011 | HTC EVO 4G Smartphone
Blackberry 8330 unresponsive to push any buttons
you know the track ball was white when you first bought it right? the dirt and oil from peoples fingers dirty it up making it unresponsive. the silver plate around the ball pops out. when you get the ball out use an alcohol swab to clean it off. when its dry put it back in. also you should be able to get a replacement ball and plate from verizon. I know sprint usually carries them.
Jul 22, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Samsung upstage wont turn on period. It is dead
I just had to buy a new phone because my Upstage had the same problem! But mine would stay on for not even 5 seconds before turning off and it would just repeat. So I went into the Sprint store and they gave me the Samsung Rant for 50 bucks even though my new for two wasn't up yet. They don't make Upstages anymore so just go get a new phone all together and see what happens :/ The Upstage is a horrible phone. Im sotrry this isn't much help. Trust me, I did my research before I decided to go into Sprint because I thought I didn't have the option to get a new phone so I was googling everything and anything I could think of to figure out what the heck was wrong with the stupid thing. Hopefully you'll be as lucky as I was.. Good luck!
Apr 22, 2009 | Samsung UpStage SPH-m620 Cellular Phone
emann023 - Thank You So Much!
I put the battery wallet away a long time ago since it is so stupid looking. After seeing your post I went and tried it out, it still didn't work, but then I turned it on and immediately plugged it in and it's working!
The phone is still **** and broken, but now I can get my numbers out of it! Thank You So Much! I'm sure if I brought it to Sprint I would get the 'Sprint Shuffle' and no help whatsoever.
Sep 09, 2008 | Samsung UpStage SPH-m620 Cellular Phone
V3 Motorola Razr won't load past Sprint Welcome screen
check software it must be 24-2-00-43r if not this mean it needs software
Jan 31, 2008 | Motorola Mobility RAZR V3
Screen problem
need a new screen if u have ineurence bring it to my store
5609 n penn ave okc ok 73112
Jan 29, 2008 | Sanyo SCP-3100 Cellular Phone
Apr 27, 2007 | Samsung SPH-a800
Samsung SPH-a800 Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
