WIRELESS NETWORK LIMITED ONLY. HOW CAN I MAKE IT FULL ACCESS?
DOES THE IP PORT AFFECT THE WIRELESS CONNECTION?
  • dragoness1
    dragoness1 May 11, 2010
    how do you mean its limited?
    Problem Solver:
  • 15 Answers
If you mean that it is displayng limited access or limited or no connectivity it means that you did not enter the correct encryption key
Posted on Jan 26, 2009
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
How do i connect my epsonR300inkjet printer wirelessly
Network printing with a non-networked printer
This model printer has only an USB printer connection andnormally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless networkthere are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a sharedprinter. Next connect the desktop computer to your wireless router with a LANcable and then configure the wireless laptops to connect to the shared printeron the desktop computer. NOTE - This desktop computer and printer must be on atall times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to thewireless router with a LAN cable. The printer drivers needs to be installed onall the wireless laptops and then the printer port needs to be deleted from theUSB port and a new IP address printer port installed. This IP address will bethe IP address of the print server.
Mar 31, 2012 | Epson Stylus Photo R300 InkJet Printer
How can I add a brother 145 printer so all laptops in the house can use it wireless
This model printer has only an USB printer connection and normally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless network there are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a shared printer. Next connect the desktop computer to your wireless router with a LAN cable and then configure the wireless laptops to connect to the shared printer on the desktop computer. NOTE - This desktop computer and printer must be on at all times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to the wireless router with a LAN cable. The printer drivers needs to be installed on all the wireless laptops and then the printer port needs to be deleted from the USB port and a new IP address printer port installed. This IP address will be the IP address of the print server.
Jun 09, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a speedport W722V router with several computers conected using wireless network. A have also an Asus WL 600g router that I would like to use as an AP to enable me to use the USB printer port to...
configure the 600G to a static IP on the same subnet as the 722, and then wire it port to port (say, port 1 to port 1, do NOT use the WAN port) - don't forget to disable the NAT/DHCP on the 600G after you assign it's network IP address (not the WAN address, local address, the WAN port will no longer matter and will be unused on the 600G)
May 09, 2011 | ASUS WL-600g Wireless Router
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Listen port in a 2 wire gateway
You need to change the listening port on your torrent application to a port that is opened on your router...or open the port that your application is listening on, on your router.
You can use this web-based port scanner tool to analyze which ports are open to your computer at this time. You will need to know your IP address.
Follow these direction to determine your IP address:
Click on the "Windows" button in the bottom left of your screen. Choose the "Run..." utility, clicking on it. Type in cmd into the run field, and press the "OK" button. This will open up a black window with white text. Now type in exactly: "ipconfig /all" you can just copy-paste what is inside of the quotes. Press enter to run the ip configuration utility. This will show a lot of text in white. If you are connecting to the internet through a wired connection (Ethernet) then find the section labeled "Ethernet adapter Local Area Connection" and write down the IP Address in this section. If you are connected to the internet wirelessly then find the section labeled "Ethernet adapter Wireless Network Connection" and write down the IP Address in this section.
Now browse to the web-based port scanner, here:
http://www.t1shopper.com/tools/port-scan/
Enter in your IP address (written down earlier) in the "Host name or IPv4 address" field. Next type in the ports you wish to scan, and initiate the scan.
Now just set your torrent downloading application to listen on a port that you have found to be open through this scan, and your application will now work!
please rate my solution
Jul 19, 2010 | D-Link 802.11g Wireless Router WBR-1310...
The printers drop out the network when connected
Hello
Double check the IP Address info for both printers - ensuring the IP Address, Subnet Mask and Default Gateway are configured correctly. Printers should never use DHCP - so this info should be configured as a static IP.
Also, try moving the connections for the printers to different ports on the router. It is possible that the router may be going bad and the printer ports are the first to show the signs.
One final tip - power cycle the router. I have used D-Link for over 8 years and have had to power cycle their routers and hubs occasionally as they sometimes lock up. This typically affects all ports - so this is probably not the cause of your issue but power cycling the device may help resolve the issue.
May 04, 2010 | D-Link AirPlus DI-524 Wireless Router
Need basic step-by-step instructions on how to install my router.
  3. Reboot the PC.
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Xp home & wireless printer won't install
Add the printer in a TCP/IP port and assign it that IP address. /Add Printer/local connection then set it to TCP/IP port and the printers ip address.
Jan 15, 2009 | Microsoft Windows XP Home Edition
Can not get my adsl modem to connect through ASUS wireless router
it could be the modem and the router has the same ip address. the asus router has an ip of 192.168.1.1, check if the dynalink modem has an ip of 192.168.1.x. if so, change the router's ip to 192.168.x.x (e.g. 192.168.2.1) then see if you'll be able to connect to the internet while the modem is connected to the wan port of the router
Apr 02, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
640 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
