Question about HP SAHARA II MOTHERBOARD HP (D768069001)
System has power, but no bios, and not booting
I have a Saharah P4 whose pwer comes on but does not show me the cmos and does not boot. I checked the power on/power off wires settings to find that they were all loose. How do i replace them?
    Scholar:
  • 73 Answers
When you say they are loose, do you mean they are loose on the power supply connecter that attaches to your motherboard? If so, you can usually just push them back down, but keep in mind that they are generally a bit loose. If pushing them back down does not work, you may have a more serious problem, either with your motherboard or PSU.
Posted on Dec 22, 2008
System unit or power supply?
The computer power supply may have failed. Do you get the "post beep"?
If not- remove the BIOS battery, move the jumper to "Clear BIOS" . Insert BIOS battery, and try to boot. Put jumper back to normal position and try boot again. If you do not get the post beep, swap power supply for a known good one, and try boot again. If it still does not boot and give you a post beep, look to see if there is a removable BIOS chip- pop it out and put it back in.place, this will clean the terminals. Go through and reset BIOS, as above, and try boot. If the system is functional, it should now boot up, but prompt for you to run the setup program.
If it does not boot, the problem is relating to motherboard/processor.
Apr 11, 2012 | Computers & Internet
Micro star mian board passward on bios ms-6724
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Intel MicroStar MS-6724 Socket 478 P4...
Concerning a thinkcentre ibm 8183 pentium 3: I put in a blank new hard drive and am wanting to instal a new os from the dvd drive...using f1 to get to different boot options..i choose boot from dvd drive...
your bios settings are not saved because of low voltage of CMOS cell.
Change your cmos cell from motherbord.
CMOs cell gives power to bios flash memory so settings saved.
Aug 15, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Cant boot my system
Check all your power cable if they are losened and the memory if is fully inserted
Aug 04, 2009 | ASUS P4SDX Motherboard
Boot sequence problem while booting
your mocs cell waltage goes down.
CMOS cell gives power to bios flash memory when it goes to low bios forgot settings after power off.
So purchase new CMOS cell it is on motherbord change it then save settings then it not forgot settings even after power off.
Thanks for using fixya.
Jul 27, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Bios password set
remove battery, boot to system settings, re-insert battery, CMOS PW should now be cleared
Jun 11, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
MY PC HAS BOOTING PROBLEM
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
http://downloadmirror.intel.com/5519/ENG/BIOS%20Update%20Readme.pdf
You'll need this link to download the bios file;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=899&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Mike
Jan 14, 2009 | Computers & Internet
Comp wont start up
The hard disk may have died. Check the BIOS and check the hard disk setting, if it appears OK then boot up with a DOS floppy startup boot disk, and select boot up without CD-ROM support, then type fdisk, answer Y to large disk support, select 4 to Display partition information.
If you see all your disk partition the most likely your hard disk is OK.
Most likely you operating system is damaged/corrupted and you will need to reinstall your operating system and drivers for all your devices.
Nov 28, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Jul 27, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
P4 comp not booting up
get working processor like that of your son's system and working ram, remove both the processor and ram on the system and substitute with the new ones and try booting.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 14, 2008 | ASUS P4B266 Motherboard
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
