Question about HP DeskJet 6122 InkJet Printer
6122 Printer says it is out of paper and will not print test page
Have reloaded driver software, updated, and removed and reinstalled paper. Will not print
  • 827 Answers
Hi Ken,
The user manual says this:
1. Verify the following:
There is sufficient paper in the paper tray (at least ten sheets).
The paper tray is not overly full.
The paper stack is touching the back of the paper tray.
2. Slide the paper guides so they fit firmly against the edges of the paper.
3. Press the Resume button to continue printing.
Sometimes my printer won't print if it has too little or too much paper in the slot. It's a relatively common sensor problem.
Try that.
If all else fails, here's a link to the user manual in pdf form:
http://h10032.www1.hp.com/ctg/Manual/c00044028.pdf
Good luck
Chris (ziraffa)
Posted on Dec 22, 2008
How to turn off test print on a HP DJ 6122.
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 06, 2014 | HP Deskjet 5940 Photo InkJet Printer
Server 2008 drivers for HP deskjet 6122
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with many Windows systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch.
Jul 04, 2012 | HP DeskJet 6122 InkJet Printer
HP 6280 Printer. Not printing. Ran diagnostics form HP software. No issues. Printer an computer are communicating. Can run alignment test and Diagnostic Print Page from computer without issue. ...
Well you definitely have a pc problem and not one of the printer. the printer just prints what it is sent and as you can print the alignment page that takes care of the printer.
You have reinstalled the driver but did you remove the old one first? I bet not. You should download the hp printer removal tool. Run it and after a restart then you can install the driver. Personally i would turn off the auto update feature as hp updates really mess things up.
I reckon after the reinstall the printer will be fine.
Jul 23, 2011 | HP Photosmart C6280 Printer
Continuous printing
try reinstalling the rpinter software, if not it is a virus and needs to be quartined, if still not resolved reinstall your windows operating system.
Mar 06, 2010 | Apple Epson Stylus Photo 870 InkJet...
I have a HP Deskjet 6122 Printer and I need a driver for Windows 7 that I can load on a flash driver to put on another computer
Windows: "Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are resident/included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 14, 2010 | HP DeskJet 6122 InkJet Printer
My printer will select a piece of paper and sounds like it will begin printing, but it doesn't print--just feeds paper through. Prior to this printer was working well--no changes were made---no software...
I downloaded the driver for hp deskjet 990c and reinstalled my printer manually. It now prints just fine--it just thinks it's a 990c as opposed to the 6122 that it really is.
Jan 04, 2010 | HP DeskJet 6122 InkJet Printer
Hp 1012 won't even print a test page. cartridge
first disconnect the unit from the computer then reset it on your computer go to control panel and add remove files and click on your printer file and select updat/repair but not remove and that will reload your software. reboot and connect your printer and start the test..that may over power the problem, if not try to reload just the driver
Nov 08, 2009 | HP LaserJet 1012 Printer
Can i install the HP Deskjet 6122 on a brandnew HP Laptop with vista OS?
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Oct 10, 2009 | HP DeskJet 6122 InkJet Printer
Splits 1 page into 4 quarter pages. For example: prints first quarter of page, then at the top of the second page prints the second quarter of the page. Reloaded software, no help. Any ideas
It would help to know the model and driver type but if you browse to the printer driver and right click the printer and click properties look and the bottom of the screen and click print test page. If that page comes out incorrectly then there might be an issue with the hardware on the printer itself like a paper sensor or rollers that transport paper thru the machine.
Let me know if I can be anymore help
TankMurdock
Apr 25, 2009 | Office Equipment & Supplies
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
HP DeskJet 6122 InkJet Printer Logo
117 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
