Question about Toyotomi TID-1800HP Air Conditioner
Smells like gas
The toyotomi is now empty and smells like gas is this a sign of danger?
  • 306 Answers
Anytime you smell gas turn off the gas at source quickly.
Posted on Dec 23, 2008
Is this a dangerous gas leak?
Any gas leak is dangerous, call him back!!!!
Nov 19, 2014 | Water Heaters
Brand new model rtg-64dvln smell gas when water is turned on..when water is off no gas smell getting code 11 gas valve not fully open but gas valve is fully open
1) if you smell gas, this is absolutely dangerous.
Call installer immediately.
If you installed yourself, get a professional technician immediately.
2) Copy following link for For error code 11: problem with gas.
Do not use flex line, bleed air from gas line, check gas pressure, incomplete combustion, etc.
Jan 29, 2013 | Water Heaters
Bmw 1995 series 7 intermittent gas odor
Hi Jerry, The smell of fuel can be the smell of danger. I suggest that if you are unable to find the source of the smell, take the vehicle for an inspection of the entire delivery and return fuel circuits. There could be a leakage and that could be very dangerous. The most likely places are the fuel filter, the gasket which seals the sender and fuel pump unit into the tank, the purge tank or anywhere along the fuel line. Don't guess as that could prove very dangerous. Get it seen to. Regards John
Dec 14, 2012 | BMW Cars & Trucks
My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
Fuel smell
the gas tank is brocken
Mar 01, 2012 | 1998 Nissan Altima
Carbon monoxcide smell when oven running ?
I have to assume your oven is gas-fired but it helps to have make and model info.Carbon monoxide is odor- and colorless; that's why its dangerous. I don't doubt that you have poor combustion and it may well contain the gas in the fumes. Check for yellow flames which are a sure sign of an improper gas-to-air ratio. If you do, you may have a buildup of residue causing the problem.
Dec 27, 2011 | Ovens
I have a kenmore electric oven, which is 13 years old. i used it two weeks ago, and it was fine. now when i turn on the oven, there is a strong gas smell coming from it that not only envelopes the...
Hello Cheryl Davis...
Your posting came in UNDER A DUAL FUEL
ELECTRIC - GAS combination...
If you are smelling gas... you are in immediate DANGER.
PLEASE turn OFF the gas at the wall...
The gas is not only toxic it is highly EXPLOSIVE ...
Do not experiment with your health & safety...!!
GAS appliances are very dangerous...
A single HOT-SURFACE ignition failure
should have caused the GAS to not flow...
If it is flowing ... you are in EXTREME DANGER.
Aug 12, 2017 | Whirlpool SF315 Dual Fuel (Electric and...
When i run my fire place it smells strongly of gas and it smells hot?
Hi, if you are smelling gas you need to turn it off now. Call your local gas company and tell them you have a gas leak. They will come out asap on something like this as it can be very dangerous. There is no charge to you for this service.
Jan 07, 2011 | Heating & Cooling
Potent smell from fridge when turned off...
refrigerant gas can be harmful in high concentration but a regular home refrig does not have enough refrigerant to be dangerous unless directly inhaled at the leak ( it would disipate faster than it ould build up) plus refrigerant is odorless and colorless so you probably wouldnt even know if it was leaking.
Your odor is most likely from a missed food item still in the frig or something that altho cleaned up left an odor behind. the most common culprit is citrus fruits. when they go bad they will leave a gaseous smell behind.
thanks for using FixYa hope that answers your question. Peyton
Feb 19, 2009 | Kenmore 53642 / 53644 Side by Side...
I will rarely say "call a professional" here because this is a do it yourself site right?
However, in this case, you obviously have a gas leak and/or malfunctioning gas valve.
Unless you have experience and training in detecting gas leaks I highly recommend shutting the gas off to the unit, ventilating the area, and calling a pro.
Gas can be very dangerous if handled improperly and a mere spark can "make house go kaboom".
If you are smelling it strong enough that you have to open windows, it is a potentially dangerous situation.
Dec 06, 2008 | Ovens
Toyotomi TID-1800HP Air Conditioner Logo
191 people viewed this question
Top Toyotomi Heating & Cooling Experts
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
