My i850 cannon printer does not print and the cartridge carrier does not move to the center when the cover is open.
My printer is jamed
Posted on Jan 26, 2009
Knocking sound when copying
It could be due to the cartridges or the encoder strip (transparent strip seated behind the cartridge carrier) has gotten loose from its position. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then slide the carrier to the center for the loading position.
  2. Check the encoder strip and make sure it is secured in its place.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, reinsert the other cartridge. Close the printer cover.
  7. Replace whichever cartridge is causing the error to appear with a new cartridge.
  8. If no error appears, try to print a document again to verify that the problem is fixed.
Problem: Carrier not moving to the loading position
If you're having trouble with the cartridge carrier not moving automatically to its loading position (to install/replace cartridges) even when the printer is on and the cover is open, please follow the steps below:
  1. Unplug the printer from the power source.
  2. With the printer cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the carrier to the center of the printer.
  3. Open the latch and remove the used cartridges.
  4. Load the new cartridges. Close the latch and then the printer cover.
  5. Re-plug the printer to the power source.
  6. After going through the startup process, try to print a document to verify that the cartridges are working and installed properly.
Feb 06, 2012 | Lexmark X6570 InkJet Printer
Cartridge error problems
Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Jan 16, 2012 | Lexmark X4650 InkJet Printer
Say no cartridge when i try to print
Jan 10, 2012 | Lexmark Office Equipment & Supplies
Cover open lexmark3480
It could be that one of the cartridges is not seated properly in the cartridge carrier. Please try this approach to fix the problem.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. Then try to print a document again to verify that the problem is fixed.
Dec 21, 2011 | Lexmark X3480 All-In-One Printer
Print cartridge would not move to loading position to allow installation of new cartridge
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 17, 2011 | Lexmark X2690 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Start buton is blinking
Open the printer cover and check if the carrier is moving to the center. (Mine didn't)
The power light is blinking because the printer carrier is not moving.
Open the printer cover again, if it won't move to the center, pull the white cable that you will see there. Please be very careful in doing so.
After moving the carrier to the center, take the cartridges out.
Close the cover again and open it. Check if it will move.
If in case the carrier did not move to the center, unplug the black box behind the printer.
Turn the printerupside down (I kid you not).
Shake the printer for 10-20 seconds. (still not kidding)
Check if you will see any foreign objects falling from the paper feed path. (nothing fell out of mine)
After that step, plug up the printer again and check if the carrier will move to the center. (Mine did)
Put the cartridges back in and print.
Jan 17, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
53 people viewed this question
k24674
jasbo
jasbo
