Question about Hotpoint Dryers
Not drying clothes
Hi every thing else is working fine ie. drum turning,going through cycle ok
  • Ty Parcher
    Ty Parcher May 11, 2010
    is it electric or gas?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Is the dryer heating?
    Discribe what your vent is like. (how long, what material, how many elbows, what kind of end cap on the outside, etc.)
  • Hotpoint Master
  • 8,220 Answers
Well if the element and limits are ok and it runs ok then you need a new timer. If you don't have the money you could clean the contacts in the timer if they are not completely burnt up. Find the heavy wire coming from the heat source to the timer. Remove it and check for continuity between that point and any other leg on the timer. Move the know to different positions. If you have no reading then the timer is toast!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
How does a cycling thermostat work on a clothes dryer
There is a sensor in the drum that looks like two strips or metal. Those sensors come in contact with the clothes when the drum turns. If there are not enough clothes in the dryer then it wont work well. Also you should clean these and make sure that the wires to them are intact. IF you enter diagnostics mode, there should be a way to test them.
Aug 01, 2014 | Whirlpool Dryers
Doesn't spin
ok have you watched the machine go through the cycle you may find that it fills heats empties ok but you get no motor action ie the drum does not turn at all this is a common problem but only noticed when then clothes are wet after spin cycle If this is the case probably carbon brushes on motor and generally you will need to remove the motor to check or replace
Mar 04, 2014 | Bosch Washing Machines
Doesn't dry clothes in spin cycle- spins but not enough
so it is the spin cycle that does not work that is the drum does not turn. Have you tried other levels such as delicate wash and see if spin works. LASTLY, disconnect power and reconnect.
Mar 03, 2014 | Frigidaire ATF6000ES Front Load Washer
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
WD63 Drain during wash but not dry cycle
the chances are you water valve has gone the drying cycle requires water to convert steam back to water, or poss your condenser is blocked this cant be cleaned easily better to change I dont know how competent you are if you have a muti meter you could test the soleniod which should have a resistence of around 3800 ohms. the valve is a triple one and the one that serves the condenser is the one facing downwards, disconnect power,take back off, turn water suppy off,take the 2 leads off the bottom solaniod only ,put your meter on contacts make sure you have selected crrect range on meter ie:10mohms if 0000 solanid faulty.Change valve if reading says 3800 valve ok change condenser
Aug 01, 2006 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
51 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
