Question about Audiovox CDM8610VM
Charging problems When going to recharge my phone, my screen flashes on and off and displays garbage characters or says "user data is being restore..." then turns off and tries to turn on again. I'm not sure if the battery is shot or if the phone is shot. It won't turn on or turn off. it just restarts and displays jibberish. I just bought this phone a month ago!
  • 749 Answers
The phone has manufacturing problem... if you have a warranty, then return it to the seller for repair or replacement, it free.
Posted on Oct 18, 2017
4 Suggested Answers
SOURCE: Phone won't turn on
Just today I had the same problem with my phone. It's not the battery. You are going to have to either take it back to where you bought it from, or get a whole new phone altogether. It's a error with the phone, not the battery.
Posted on Jan 29, 2007
SOURCE: Phone will not turn on (boot) fully - powers on over and over
maybe it needs to be charged more
Posted on Feb 24, 2009
  • 8 Answers
SOURCE: "User Data Is Being Restore..."
Ok - been researching this for a year or so - Apparently this is likely to happen if you delete something on the phone like contacts or messages or apps etc. and the phone doesn't have the memory available to handle the process... there is also some data that is added or moved during the shutdown process, so even if it looks ok to go, there might actually be a problem on restart. Not quite a solution, but at least an answer... It would appear from all sources that recovery from this is not possible - I have not found anyone who successfully even reflashed it with original software.
This is my 8th 8915 which is also prone to this - and it fits exactly with the pattern of destruction. I actually was avoiding deleting items via data cable b/c someone advised me that would be bad... turns out to be just the opposite! So watch your memory limits when adding contacts and apps with this phone.
My guess is that this is applicable to the entire family of pantech pn-200,212,215,300 .utstarcom 7025/7075.audiovox 8610, 8900, 8912, 8915, 8920, etc, that were similar
Posted on Feb 25, 2009
My phone will not charge
Hello, Maryra -
You may need to replace the rechargeable battery for your cell phone. Rechargeable batteries do not last forever.
Without knowing the make and model of your cell phone and without knowing where you reside, I cannot direct you to a source where you can purchase a replacement battery for your cell phone.
Best wishes.
Aug 01, 2018 | Cell Phones
CHARACTERS ARE ILLEGIBLE ON THE DISPLAY WINDOW.
Hi
It seems the problem with display as well as to the charging unit. Display problem can be repaired only br replacing the display. And for your set, its not worth to get the display replaced. You can get the handset to your near service man to check whether the power charging unit works well.
Thank you
Sep 08, 2008 | Motorola Mobility MD451 Cordless Phone
What is a problem when My Phone does not displaying the keypads when im trying to type sms or mms
Software of your phone is corrupted. easiest way out is to factory restore your phone....BUT THIS WILL EREASE ALLL USER DATA INCLUDING PHONE BOOK ENTRIES STORED IN THE PHONE MEMORY....However sim and memory card data will not be effected.........to do this...go to settings and select restore factory settings/full factory restore...ur phone will ask for security code....for code refer user manual..or enter code that u have previously changed.......if this fails then switch off phone,....remove battery....reinsert battery....press volume up,and Power button for about 15 seconds.........till boot mode appears and u get some text written on screen....using volume up key scroll thru the text and select erase all user data/restore....now press power button for about 2-3 seconds......process begins........restart phone.......this should solve the problem...........but if still problem persists then u will have to visit a service person who will flash ur set using special tool loke...volcano box.
May 20, 2014 | HTC Hero Smartphone
My lock button and screen won't work
Please try Hard Resetting and check if it works.To reset, you can refer to the following method, which can reset the phone and erase all the user personal information.1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.2)When display press the Menu key at the bottom of the screen;3) Choose "Wipe data/factory reset" through volume key4) Press "Camera" key to confirm the above item5) Choose "YES...delete all user data"6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Jan 04, 2013 | ZTE Score
My Motorola Defy will not hold a charge. Had full charge at 8:00 Am and by 2:00 PM battery was dead. No apps running or Wi-FI on. Second day in row this has happened
The DEFY is feature-rich and can run a virtually limitless number of applications, making it useful for many tasks. Your particular usage will affect how long you can go before recharging your battery. Playing games, running applications, and surfing the Web increase the power use of the computer-like functions of the DEFY Calling and texting utilize its phone functions. Depending on your use mix, time between charges will vary. We know you want to use the device to its fullest and offer you these tips to help you get the most from your phone while going as long as possible between charges.
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tip: It may take several charging cycles for your battery to reach optimum performance.
The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
Tips to extend battery life:
  • During initial set up of your MOTOBLUR account, your phone's battery may drain faster than usual due to the amount of data transferred. After the initial sync, and a few charging cycles, your battery will reach its maximum capacity.
  • We strongly recommend to keep the phone attached to the charger during the MOTOBLUR initial sync.
  • When not transmitting a lot of data or surfing the Web, set your device to connect to 2G network.
  • When setting the phone down after use, quickly press the power key to invoke a blank screen. Selecting a shorter back light duration will also help conserve power by blanking the screen when not in use.
  • Lower the display brightness.
  • Use the AC adapter to charge your phone whenever possible.
  • Toggle Bluetooth, Wi-Fi, and GPS on or off as needed. There are some apps that can help do this easily. While we do not endorse or guarantee these solutions, or provide support for them, some owners have reported success using an application called "Battery Widget " which can be downloaded from Android market.
  • Ensure applications are closed when not in use.
  • Clear all notifications from the notification bar as much as possible. Click Here to learn more about notifications.
  • We suggest charging each night so you start the day fully charged and ready to go!
Motorola DEFY Battery Manager - Benefits
A feature called Battery Manager is now part of the DEFY software
  • It provides options for significant battery savings by reducing data traffic when not needed, and by dimming screen when battery is low.
  • Two optional settings:
Data Timeout
· With this feature: After a period of inactivity, background data updates stop until the user starts using the device again.
· Without this feature: background data is constantly updated (Email, Social Networking, News Feeds, etc.), even overnight.
Auto Brightness
· When Battery Level gets low, screen automatically dims.
Battery Manager: How To Use It
To access battery manager
  1. From the home screen press the menu key
  2. Tap settings
  3. Tap battery manager
Three Modes are available:
  1. Performance Mode (default) - Data Timeout and Auto Brightness are OFF
  2. Smart Mode - Data Timeout and Auto Brightness are ON with different settings during Peak and Off-Peak times of day. User can change various settings.
  3. Battery Saver Mode - Data Timeout and Auto Brightness are ON with settings to maximize battery savings. User cannot change the setting
May 24, 2011 | Motorola Mobility Defy Cell Phone
My flash will just not turn on. I have a casio exilim EX-Z35
At back camera, have lamp flashes orange where to indicate flash is charging and to tell image will not recorded(disable). You will can not take another flash until that lamp is stop flashing orange to indicate charging is full. in other view, please check at lcd screen have appear flash icon.
click button play mode to display menu. change set flash to on if flash icon is not display
for user manual
User manual trobleshoot
May 09, 2011 | Cameras
I have a flash application running on a Samsung galaxy tablet (Android 2.2 OS). The app requires that the user logs in. The app uses the tablet's native on-screen keyboard for entry of the username and...
This is a common problem with flash based inputs on touch screens. Things are a bit better on version 3.0 of Android. I hope that the galaxy tab is going to be dated to this version someday.
Cheers
Feb 28, 2011 | Samsung Computers & Internet
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
Handspring Visor Username Deleted; How to Add on Device
To recreate your problem, I have setup the my Visor with no username, placed it in the cradle, and connected the cradle via USB port.
In this configuration, I do receive the same error message that you reported. Multiple issues can cause this error to be generated.
1. Place your Prism in the blue charging cradle. Confirm that the green charging LED is flashing or illuminated (below the power button on the Prism). If the green LED is not lit, then reposition the Prism until it is. If the green LED still doesn't illuminate then check the cradle and it's connectors for dirt and debris. Also check the copper connectors on the Prism for dirt and debris.
2. Depress the grey HotSync button on the charging cradle. The error message will appear. Press OK to clear the error display. If nothing happens when you press the grey button you need to check the copper connectors in the blue cradle and the bottom edge of the Prism for dirt and debris.
3. Check the upper right hand corner of the Prism display for the HotSync application. If any characters appear on the top line, opposite the HotSync header, then that is your username. If no characters are present, then there is no username in the PDA.
Regardless of whether there is a username in the Prism, the HotSync should still be possible. Once you successfully connect the cradle to the USB port and successfully connect to the desktop computer, a popup window will ask you to Create or Select the HotSync User.
Do you receive this popup window on the PC?
If not, your setup or connection probably has an issue.
4. Look at the Prism HotSync screen. Underneath the HotSync icon in the center of the display is a Drop Down selection. The options are
a. Direct USB/Serial
b. IR to a PC/Handheld
Since you are using the cradle, you should select option a.
Once you have confirmed this setup, you need to confirm the desktop computer setup.
5. Be sure to start the HotSync Manager Application on the desktop computer.
6. Left Click on the desktop computer HotSync Icon in the system tray, and confirm that Local USB has a checkmark beside it.
7. Depress the grey HotSync button on the charging cradle again. If the HotSync popup still does not appear on the desktop computer, left click on the HotSync icon and uncheck Local, Modem Network and Infrared and then depress the HotSync Button again.
There is a hidden method in the Prism for deleting the user name.
  • Open the Memo application on your Prism.
  • Tap New.
  • Enter the ShortCut character.
  • Enter a period '.'
  • Enter the number 5.
Whether you entered the shortcut character, period and 5 correctly or not, the characters you've entered will disappear and the memo pad will remain blank. To see if you succeeded:
  1. Depress the Grey HotSync button on the cradle
  2. Your user name appears in the upper right corner of the screen: if it's blank, then your user name has been deleted. The next time you HotSync with this device, you will be asked to create a new user name.
Note: Creating a new User name, will not affect the data stored in the Prism, other than initializing the user name.
There is a freeware application to Change the user name on the Prism, but you would need to HotSync to the desktop or beam the application from another Palm PDA to install it.
Jul 12, 2009 | Handspring Visor Prism Handheld
I am looking for a users manual for ntl d8500 dect cordless phone.
I have solved the problem I had with my phone. I just messed around with setting and by chance found the problem.
Thank you for your concern and support.
Yours Truely.
Mary Finnegan
Mar 25, 2009 | NTL Lands Phones
Audiovox CDM8610VM Logo
Top Audiovox Cell Phones Experts
Marvin
Marvin
John Porter
marty morrison
marty morrison
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
