I have an HP Photosmart C7180 printer and I think some of the black inkjet spray nozzles are clogged. I get a horizontal streaked printout from the black head. I have tried everything. I have run the Clean Print Head routine about 10 times and nothing has changed. I tried sliding the printhead to the middle and adding some isopropyl alcohol to the cleaning pad underneath where the printhead parks itself and letting it soak itself. I also tried taking an empty cartridge, cleaning it out, adding isopropyl alcohol, installing and printing about 40 solid black pages to flush the nozzles. Nothing has helped. One website recommended taking a syringe full of alcohol and shooting it through the bottom hose/port to the printhead where the ink cartridge attaches to the printer. Does anyone have any experience doing this or any other recommendations? I'm not afraid of taking drastic or risky measures since my next step is to throw it away. Seems like such a waste, it was a good printer when it worked.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
SOURCE: Streaks / Bands of broken print area
No cleaning was successful, finally replaced the printhead and solved the problem.
SOURCE: HP L7680 Printer Head Problem
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Step two:
Increase the print quality mode
If
reprinting did not help, try increasing the print quality mode.
In the
application you are printing from, click File, and then click Print. Make sure
the printer is selected, and then click Properties.
Select the Paper/Quality
tab. In the Print Quality area, choose the next higher quality setting. If the
current setting is Draft, choose Normal.
If the current setting is Normal,
choose Best.
Step three:
Print in grayscale (black area streaking only)
If the
streaks are in a black area of a black and white printout, change to grayscale
printing.
NOTE:- This
step does not apply to color printouts.
In the
Make sure
the printer is selected and click Properties.
Click the Color
tab, and select Print Grayscale and High Quality.
Step four:
Clean the printheads
If the print
quality is still bad, clean the printheads.
Make sure
the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings,
Print Settings, and then select Printer Toolbox.
Click the Service
Tab.
Click Clean Printhead,
and then click Clean.
Step five:
Align the printheads
If the print
quality is still bad, align the printheads.
Make sure
Open the
printer Toolbox, and select the Printer Services tab.
Click Align Printheads.
The Align Printheads window opens. Click Align.
The printer
prints an alignment page. The lines in the patterns should appear to be
straight. Click OK when the page finishes printing.
Step six:
Calibrate the linefeed
If the print
quality is still bad, calibrate the linefeed:
Make sure
Open the
printer Toolbox and select the Printer Services tab.
Click Calibrate
Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven:
Replace one or both printheads
If the print
quality is still bad after performing all the above steps, one or both of the
printheads will have to be replaced. Print a PQ Diagnostic page to see which
printhead should be replaced.
Make sure
Press the Setup
button.
Press 1 and *
simultaneously.
Look at the
color blocks labeled Test Pattern 2. Some or all of them could show white
horizontal streaks. If none of the blocks are streaked, the printheads are
okay.
If the Black
block has lines – replace the KY printhead.
If the Cyan
block has lines – replace the MC Printhead.
If the
Magenta block has lines – replace the MC Printhead.
If the Red
If the Green
SOURCE: Blank Ink not pumping to print head
Turn off the device after removing the printhead
After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
SOURCE: I have an HP Photosmart 8250. I changed the
please if you are not professional technician then don't do this.but you can use some cartridge head cleaning solution.on the print head.if problem not solve then replace the cartridge.
SOURCE: How do I manually clean
By manual you mean that it needs windows to clean it right? (you cannot physically clean it yourself) Go to your printers, right click and in properties somewhere you should find "clean heads" somewhere. Try print test after. Should be good.
