Question about Haier Heating & Cooling
Vizoo t.v. remote control turns on my air conditioner
When i turn on channel 9 the air comes on
  • 69 Answers
You need to contact the 2 manufactorers and ask if either product has the ability to change the remote coding.
Posted on Dec 22, 2008
Does anyone know what's going on?
Unfortunately the bandwidths of remotes often crossover. You can put tape over the ir sensor on the ac.
May 21, 2012 | Haier Heating & Cooling
Cannot turn unit on with remote
the problem lies between the remote sensor of the unit or the remote control itself.
You need to test the remote with another unit or test another remote with the unit to actually confirm where the fault is coming from.
Regards.
Jan 05, 2012 | Sanyo Split System Air Conditioner
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
How to program remote to a durabrand dvd player
turn the switch on the top to the left one click the hold select and mute until the green light blinks twice then press 9 then 9 then 1 light will blink twice then channel up till it turns on the DVD player and press select if you miss the code repeat and channel down till you turn on the DVD player
Oct 16, 2010 | Universal Remote Control DIRECTV Universal...
I bought a element 32 inch tv from someone which didnt come with a remote, i went and bought a universal remote but i cont seem to get it to program
best bet is to get a direct tv remote and program that to the TV will work to put code in just switch the top switch over to TV hold select and mute till lights blink then press 9, 9, 1 lights will blink then channel up till the TV turns on if you miss the code same steps and channel down till you turn tv off
Oct 16, 2010 | Televison & Video
Remote control codes needed
turn your device on, press device key(tv,dvd,etc) press and hold Setup (led blinks twice), pres 9-9-1(led blinks twice) press power key , press channel + repeatedly until device turns off, press setup untill device turns off. good luck
Mar 22, 2009 | Televison & Video
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
We have a fujitsu reverse cycle air conditioner. Last night when we went to turn it off with the remote it did not respond. We needed to turn it off at the switch outside the house. We replaced the...
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective.If the remote control still good try to press the RST or RESET button on your remote control and try. If wont works it means that the reciever board in the indoor unit is defective.
Aug 20, 2008 | Fujitsu Heating & Cooling
Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Jan 02, 2008 | Heating & Cooling
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bonded Repair
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
