Question about Apple iMic, USB Audio Interface Sound Card
Memory card reader not working
I formated my laptop and my memory card reader is not recognising the memory card
    Master:
  • 368 Answers
You need to check on another port or computer .
Posted on Jan 28, 2015
    Genius:
  • 1,234 Answers
Hello Mr
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Ps2 not recognising memory card
    Try formatting the card. If formatting the card doesn't work, either the reader inside your PS2 is broken, or the card itself is damaged somehow.
    Jul 05, 2012 | Sony PlayStation 2 8MB Memory Card - Black
    Tip
    How to Format A Memory Card Using A Computer
    If you are having problems where your camera or other device will not format or recognise your memory card, this is often because the card has become corrupted or the device is an older type and does not recognise the file system of the card.
    You should always format your card with your camera or device (not your computer) every time you need to do this. This prevents the possibility of data errors and corruption.
    However, if your device is refusing to format or will not recognise the card you can often resolve this by getting your computer to format it for you.
    This often helps the camera or device recognise the card and make it functional again. If a format on your PC fails and the card is still not recognised then the card is either faulty or in the case of a camera exceeds your cameras max capability. In this case you will have to use a new card or one with a lower memory capacity.
    If you have a card reader on your PC this is the easiest way to access the card with the computer. If not, a multi card reader is a cheap and useful device to have.
    Be aware that formatting the card erases all information and or photos stored on it.
    To format the card with your PC do the following:
    1) Insert the card into the card reader.
    2) Go to 'Start' - 'My Computer' and then find the card icon which will show as 'SD Card Drive' or 'Compact Flash Drive' or whatever card type you are using.
    3) Right click on the relevant card icon. you will be presented with a list of options. Go down to Format and select this option.Now select a File system type.
    PLEASE NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
    4) Click start to begin the format process.
    5) When the process is complete, take the memory card out and insert it into your device. If the procedure was successful the device should recognise it and it should work.
    Note: Old cameras
    Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
    - Error message asking to re-format the flash card.
    - Error message that the flash card is not formatted.
    To resolve the above error, backup your data and reformat your memory card in FAT file system
    Hope this Tip has helped. If so please take a moment to indicate this using the Yes/No buttons below.
    on Dec 31, 2009 | Cameras
    I got a "card error"
    Welcome to FixYa.
    There are three reason why do you get a "card error" when trying to format your card.
    * a new memory card or unformatted camera.
    * a memory card that has a file, this camera can't recognise or one has been take from another camera.
    * always format the memory card using the camera. If you insert a memory card that has been formatted using other cameras, memory card reader, or PC's you will get this error message (card error)
    Feel free to send us your comments or suggestions if this solution was helpful.
    Thank you for using FixYa.
    Apr 11, 2011 | Samsung SL102 Digital Camera
    Please solve my problum how to format nokia 6233 phone memory with computer
    insertyour usb cable to your system and connect to your phone after the connection between your system and your phone when the system recognises your phone look the computer names your memory card and your phone memory either removable disks so dont open your memory card on the system just right click and go to format you can format using the quick forrmat or the other
    but if you are using a card reader just insert your card memory card into your card reader and insert your card reader to the system and right click then in the options that would be displayed click on format then you can format your memory card that way
    Jan 22, 2011 | Nokia 6233 Cellular Phone
    The camera is not recognising the memory stick
    If this is a new memory stick, some cameras require you to format it using the utility on the camera. If you haven't done so, you can try to format it. This will delete all contents on the memory stick.
    If this is an old memory card, chances are it is already corrupted. Try to attach it directly on your laptop either on the SD card slot or a USB card reader.
    Jan 12, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
    I have inserted a 4G card into my HTC snap phone but the device keeps saying my phone memory is low. It doesn't seem to recognise the card.What should i do? how can i transfer the phone data to the storage...
    Use card reader and format memocard in PC/laptop using FAT format. then insert it to the phone and restart the phone. (Snap works fine with 8GB, at least mine does).
    Oct 19, 2009 | HTC Snap S522 Cell Phone
    Sony memory stick pro 128mb has docs on it I need. when i plug it in to laptop, it either doesn't register or says USB device not recognised. help!!!
    I'm assuming the docs are important. What I would try to do is buy an external reader which cnnects via USB and hope that it is the port on the computer that is not working.
    Sony MRW62E/S1/181: an external memory card reader/writer that can address 17 different memory card formats. It sports a Hi-Speed USB 2.0 interface and draws its power directly from the USB connection. The MRW62E/S1/181 can be connected to both Macintosh and Windows computers. Cost is around $30.
    Sep 02, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    I have a new kingston 4 gb memory card and my camera will not use it , it says it needs to be formated ,how do you format the memory card Kodak,easysharecx7300 camera
    If your computer has a memory card reader, insert the card into the reader. Or else, you can purchase a card reader quite cheaply. Now in your PC, using windows explorer (Right click 'start' button and select 'explore' from menu), locate the card. It will usually be recognised as a USB mass storage device, and will be assigned the last drive letter. Right click over the drive letter and select 'format' from the menu.
    I think you should be able to just plug the camera in to the PC with the card in the camera and the PC would be able to recognise it..
    Jun 23, 2009 | Cameras
    Acer 5920 does not work with sandisc 1gb memory card
    Your Minolta camera uses file format, which is not recognized by PC and vice verse. When you insert, PC can't read it, and asks to format. But when it is formatted for PC, your camera can't read it. Try to format it in camera, if it's not possible, then get a new memory card and use USB cable to copy images.
    Feb 15, 2009 | Acer (AST135-U-S3100) PC Desktop
    External Memory Card Not Recognised
    It sounds like your phone's card reader is broken or has debris inside.
    To clear debris, use a blast of air to the socket to clean it.
    If your card reader is shot, you need to replace the controller.  If the phone is under warranty, get it replaced.
    Dec 13, 2008 | LG Prada KE850 Cellular Phone
    Apple iMic, USB Audio Interface Sound Card Logo
    146 people viewed this question
    Top Apple Computers & Internet Experts
    marty morrison
    marty morrison
    Paul Carew
    Martin Buck
    Martin Buck
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
