Question about Dell Latitude D600 Notebook
My dell lattitude D610 laptop wont charge battery
Used to work fine, but when on battery power the battery light glimmers on and off weakly in green, but the charging light does not light up. Tried new battery but does make difference. Is there something wrong at motherboard end?
  • 3 more comments
  • paul_pearce Dec 22, 2008
    Am only able to run it on AC power at present. Cheers P
    thanks for trying again, but the battery and its connectiosn are clean. P
    connections on laptop seem clear and clean. P
    The power supply transformer failed before this problem started, so had to replace striaght away with a generic rather than Dell supply. The battery was dead and wouldn't charge at this stage already, hence need for instant supply cord replacement. The new cord has variable settings, nearest being 19v whereas original kit was 19.5v. This works all the laptop options well with the boot up message that this is a varaiance to the normal input voltage. The battery was not charging before the cord supply failed though. The battery is rated at 11.1v Type C1295. P.
    The laptop uses 19.5v and the supply is 19v. I can change the setting to 20v if this is better, but I thought the lower nearest number was most advisable. P.
  • Dell Master
  • 4,806 Answers
Before you come to that conclusion, try it on AC power only
get back to us if the problem is still the same
regards
Posted on Dec 22, 2008
  • 3 more comments
  • Lee Hodgson
    Lee Hodgson Dec 22, 2008
    HI there, its probably not the motherboard, if it was the computer wouldn't boot at all.
    Have a look at the connections where the battery goes for build up of dust or especially hair which could cause the battery not to charge
    regards
  • Lee Hodgson
    sorry i meant check the connections on the laptop
    regards
  • Lee Hodgson
    ok check the voltage on the power suppy against the voltage on the laptop, this is usually 19v either way it should be the same on the power supply and the laptop
    regads
  • Lee Hodgson
    I think the universal power supply may be the problem, don't look at the battery for voltage but rather the laptop itself, this will displayed underneath the laptop near the serial numbers, check the laptop doesn't use less than 19v
    If it uses 15-17 volts then change the setting on the power supply to match.
    I would recommend that you get the appropriate power supply for it as these so called universal ones cause more problems than their worth
    regards
  • Lee Hodgson
    As a pc technician, thats what i would advise, the only way i could now work out if it was a problem with the motherboard or bios because of the original power supply fault is go into the bios settings and load the default settings as the shock may have damaged the bios (update the bios from the computers manufactuers website while you are using it on AC power), if this does not work get another power supply, try and borrow a compatible one from a friend and see if the battery charges, that will tell you its your power supply and it has to be changed. If you still get the same result then the feed back caused may have damaged the motherboard. If thats the case your very lucky the computer works at all
    kind regards and plesae keep me posted
My Dell Lattitude 610 will not power on when the power button is depressed. The battery has been switched with a battery that was fully charged, still no sign of life. What can I do?
Remove the battery and power on the laptop with the AC adapter and see if it powers up. If not then you probably need to have the motherboard replaced.
Jul 02, 2011 | Dell Lattitude D610
Dell lattitude d610 notebook wont power up. Got new battery yesterday, worked fine. Shut it down & now it wont power back up & yes the battery is fully charged.
Take the battery out (1 screw in the bottom of the case, then it pops out with the tab) and attach the power adapter, and see if it boots up now. If it does, you have a problem with your battery.
Did you have this problem before the new battery?
Aug 11, 2010 | Dell Latitude D610 Notebook
Dell d610 wont turn on ac adapter light is green
There is a small IC that Dell solders into their power supply as well as their batteries. When this parts fails you will have the type of problem you are having now. If you do a search on the web you will find a large number o sites that discuss this. Unfortunately there is no fix other than replacing your power supply. I had to do the same thing myself for the Dell laptop I use.
Nov 02, 2009 | Dell Latitude D610 Notebook
Dell Latitute D610 is no longer working under AC Power
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Oct 08, 2009 | Dell Latitude D610 Notebook
Dell 100l has two green flashing lights at the front
Kindly remove the ram and clean it and fix it again.
Sep 22, 2009 | Dell Latitude 100L Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
I have a dell lattitude d610 that it wont turn on at all i already check voltage on the charger it gave me 18 volts and battery is fully charge when i plug it nothing turn on neither lights does this...
Laptops are notorious for having the adapter plug come loose from the motherboard although, most laptops will power off of the battery if this happens (if the battery has a good charge). Some laptops have a DC power board that can burn out. Or in some cases, It can be the power button bar. If you are not comfortable trying to repair it yourself, I suggest taking it to a reputable repair shop but it will probably cost you quite a bit to get it fixed. If you know someone who does this type of repair you might check with them.
Dec 06, 2008 | Dell Latitude D600 Notebook
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Dell Latitude D600 Notebook Logo
634 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
