Question about DeLonghi DCR902T Coffee Maker
Flashing Light The flashing light of the power button has been flashing for a week and I don't know why. From reading the manual, I haven't found anything helpful.. Is something wrong with my machine?
  • Anonymous Nov 11, 2008
    Same problem, the ON light keeps flashing, called the customer service and basically told to just get a new since warranty timeframe had expired. Do not recommend Deloonghi Coffe maker.
  • garrod007 Mar 22, 2009
    no manual , want to set timer to brew coffee automatically
Drives you nuts doesn't it? I was about to throw mine out...could never tell if it was on or off, let alone program anything....but Here is The Solution!
Hold the hour and minutes buttons down simultaneously for about 10 seconds till light stops blinking and it will reset.  I was so happy to find this info on:
http://kitchen-stuff.info/gear/Coffee_Tea_and_Espresso/Coffee_Machines/Drip_Coffee_Machines/DeLonghi_America_Inc_DeLonghi_DCR902T_Retro_Drip_Coffee_Maker_with_Timer.html
Posted on Dec 08, 2008
Press the hour and minute buttons together, hold for a second and let go. It will reset the electronics. Nothing is likely wrong with your machine. RKF
Posted on May 25, 2007
    Genius:
  • 1,074 Answers
Unplug the machine let it seand for a day and plug it in back if that does not work have a tech look at it.good luck
Posted on Apr 08, 2007
The power button keeps flashing
If the tv is not coming on, then you may need a new tv. If it is coming on and its just the light that bothers you, a quick fix would be to put a small piece of black electrical tape over the light. I read thru the owners manual and found no setting for this specific issue. Id suggest contacting Olevia. Hope this helps a little.
I’m happy to assist further over the phone at https://www.6ya.com/expert/taw_96620811415579f2
Sep 30, 2014 | Olevia LT42HVi 42 in. LCD Television
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Daikin FTY45EV1A split system wont turn on, has flashing timer light on. I turn the unit on and off by the remote, still doesn't work. What does the flashing timer light mean?
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Jun 14, 2011 | Heating & Cooling
My dlink dir600 is not flashing light, both at the power. it just keep flashing an orange light. and wifi/wlan light doesn't show any light at all. can somebody please help me?
Seems from the manual to be, that there is a problem with the power adaptor.
Haven't yet managed to find out if it's the router or the power adaptor that's the problematic part.
But do you have another adaptor with the same specs, you can try using that.
/Sebastian
Nov 01, 2010 | D-Link DIR-600 Router
Red light flashing on power button after attempting a scan, making a funny jerky sound like a jammed mechanism
Found online epson manual, found that lock tab on the back of the scanner had been bumped across to "lock" position.
Jun 18, 2009 | Epson Perfection V700 PHOTO Flatbed...
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
2 Red lights for player1 and player2
Check the light on the power supply and if its orange that means that the console is on stand by mode, The light on the Power brick should be green when the console turns on. if the light turns red that means that the power supply needs to be replaced. call xbox support and check the warranty status of your 360
Mar 29, 2009 | Microsoft Xbox 360 Console
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
DeLonghi DCR902T Coffee Maker Logo
1,265 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
