Question about Sharp Office Equipment & Supplies
Red Image in form of a man is shown on my copier
I just bought a sharp copier (SF-2218), I used it for some times but is not warming up as usual rather, a red image in form of a man is shown on it .
    President:
  • Sharp Master
  • 990 Answers
Already been taking care
Posted on Dec 22, 2008
Sharp sf 1118 shows error code of red image inform of a person beside or close to the green digital counter . Please I need.a solution thank you.
it means that the machine need service/ to change the P.M kit on the machine and clear the error code by entering the simulation on the machnie
Oct 14, 2015 | Sharp Office Equipment & Supplies
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
How can I reset the password/ Copying code on SF 2540 copier
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Sharp SF 2540 Copier
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
We have a Sharp SF 2020 copier - can we use it as a printer?There are no ethernet or usb ports on the copier. Is there a jet-lan type of card for it?
No( There are no Sharp SF 2200 Ethernet and USB- ports, There is no a jet-lan type card. sorry. For you any help((
Sharp 2020 Code Description CC Original detection problem CH Lit Steadily: Sorter not installed, or not turned on CH Flashing: DV unit not installed, not connected properly, or not latched in place properly F1 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive. F2 Sub code 31: Image density sensor. Could be a problem with light level. Sub code 32: Drum mark sensor problem. . Does not see mark on drum or sensor not working properly. H2 Sub code 00: Fuser thermistor open. H3 Sub code 00: Fuser temperature too high. H4 Sub code 00: Fuser temperature too low. Lamp, thermal switch, connections. L1 Scan forward problem. Motor, sensor, board L3 Scan forward problem. Motor, sensor, board. L4 Drive problem; main motor, gear, sensor, bind. L5 Lens problem. Motor sensor board. L8 Sub code 01: Zero cross. P Paper feed problem or no paper PC Card counter not installed U2 Sub code 01: Memory loss. U4 Sub code 00: Communication problem between copier and duplex unit. U5 Sub code 00: Communication problem between main board and ADF.
Mar 12, 2010 | Sharp SF 2020 Copier
Output of my sharp 7850 copier is very dark
Hello sir; Check out the exposure lamp is on or not, please let me know.
Mar 09, 2009 | Panasonic Workio DP-2000P Copier
I have been using sharp copier- table size(SF-2218). but recently a red image in form of a man is viewed which is stopping the copier from warming up.
Dear sir; The symble of red man, means need PM service, you need to replace DEVELOPER,
slide out developer unit and remove toner hopper(2 screw),Empty old developer,replace with full bag, reassemble, install back to the machine. power on, press "clear", "pause", "0", "pause" keys, then enter 25, press print, enter 2, press print,machine will run for 3 minutes, the "pause" key also call "interupty" key, when machine stop then press "clear" then enter 20 press "print" enter 01, press print, enter 0, then press clear key enter21 press print enter01 press print,enter 0, press print press clear twice to end the simulation.
If you not clear or need more help just email me, I always around, good luck!
DON'T FORGET GIVE ME A RATING
HAVE A HAPPY HOLIDAY !!!
Dec 22, 2008 | Office Equipment & Supplies
No bottons are working
This means the developer unit is not installed . Check and instal.
May 16, 2008 | Sharp SF 2020 Copier
"little red man"
The "Little Red Man" stands for that the copier has reached it's set "P.M." counter and it is time to have the copier to have a general cleaning done. It is just a counter that comes up 10k, 20k, 60k, 80k or it is set not to count at all. It should not affect the copier it self. It has to be reset and set to "0" for no P.M. count.
Apr 24, 2008 | Sharp AR-160 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
