Question about Broan-NuTone Allure III QS330SS Kitchen Hood
Nutone Allure fan has disco lights.
-installed a used fan
-worked fine for 1 month
-light are now turning on and off by itself
  • Greg
    Greg Dec 23, 2008
    Have same problem although it's the fan itself that comes on at high speed and then goes off on it's own. Lights flicker but I can control them. Sounds like board I think... I'm sure that'd be a cheap fix....... not
  • Anonymous Feb 21, 2009
    My allure hood range lights all flicker on and off and now will not work. What do i do?
  • 38 Answers
Its definetly the control board!!!
Part #R111632
Price $110.00
Definetly not cheap...
Posted on Feb 08, 2009
Last night both fan and lights worked on my hood fan and lights. This morning neither are working. Checked house fuse box - everything ok there. what could be the problem does the allure have a fuse inside...
could be simething as simple as a disconnected wire, prior to calling for help, check these items if you feel okay with that , first turn off the circuit breaker and where the house wires come into the unit,, remove the wire nuts and check for burned areas,, if thats ok, reattach them and move to the switch or switches, unhook the wires, ( make note where each one goes ) and check them with a meter , this is probably where your problem will be,
Jul 10, 2011 | Broan-NuTone Allure QS130SS Kitchen Hood
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Fan and lights come on and go off all day long on their own
We installed our Broan-Allure range hood about ten years ago. On three seperate occasions since, the fan has randomly turned on and none of the control buttons would turn it off. After a while it turns itself off. During those same times, when you turned the lights on, they would blink before finally staying on. On each occasion, I have removed the screens and metal underpieces to gain access to the circut board. Once you can see the circut board, remove and replace the 3 Amp fuse that is mounted on the board. (Radio Shack part # 270-1054)...even if the fuse looks good, replace it. Each time this has work for about three years, then it acts up again..
Oct 13, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Changing fuse on Nutone Allure Ws2
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
Aug 16, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
ALLURE II STOPED WORKING ??
If nothing is working Lights/Motor Nothing, Its the small transformer. Theres 2 transformers. you will see blue and yellow wires coming out of it. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Mar 20, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
New fan not working but lights work
There is less than 120v getting to the fan. Its possible that the lights will turn on etc. Take an extension cord and plug it in another plug and grab both power wires from the fan and stick them in other end of extension and I do service calls for broan & Nutone
Jean-Marc
try it out. Im sure your not getting 120v completelty.
Feb 05, 2008 | Broan-NuTone Allure QS130SS Kitchen Hood
Random fan speeds and light levels???
I have the same issue. Have to reset the breaker to make it stop. Bet it is a bad controller (design fault).
Nov 13, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone Allure® I WS136BC Kitchen...
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
386 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Marvin
Marvin
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
