Question about Hitachi Travelstar 80 GB Hard Drive
Hp 530 does not recognize 2.5 hitachi sata hdd
4 Suggested Answers
SOURCE: new Samsung HDD hangs up with boot
The drive may be faulty. See if the problem happens with the same drive in another computer.
Posted on Sep 22, 2009
  • 1705 Answers
SOURCE: is there a jumper setting
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Posted on Mar 26, 2011
bronk50
  • 27725 Answers
SOURCE: MASTER PASSWORD FOR HITACHI 320GB HDD
We don't supply master passwords
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Posted on Dec 19, 2012
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
MY HITACHI 1 TB HARD DRIVE IS NOT BEEN RECOGNIZED BY MY SONY LAPTOP. IT WAS WORKING WELL 2 WEEKS AGO , HOWEVER TODAY I UNPLUGGED THE HARD DRIVE DURIN TRANSFER SOME FILES. UNTIL THAT MY COMPUTER STOP...
hello, if the hdd is not being recognize by your Sony laptop, may be because the device is not responding any more, anyway this is still new you can have that Hitachi replace via the warranty, but your not suppose to tell them what happen cause that would fall for intentional damage. Just tell them it stop working. Thank you for using Fixya
Mar 06, 2011 | Hitachi 1 TB SATA Hard Drive
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I have bought new hard drive of 160GB Seagate IDE. because my HITACHI 250 GB sata drive was giving problem. i have installed O/S in my new 160 IDE. but the system is taking my old sata HITACHI as the...
At boot up press F2 to enter the BIOS. That is where the change has to be registered for your PC to recognize the new HDD. So when you get the first meny there you will find the HDD. If not, then auto detect the HDD. Within a second or two your new HDD will be recognized. Also from the back of the new HDD. ie, the Seagate, check if the Seagate is the master. If not, then you will find a diagram there which tells you how to change the jumper so that your HDD will behave as master. And I hope you are not using the other HDD as well?
Nov 01, 2009 | BenQ Cameras
SATA 2 HDD
I think, one possible way is to manually force sata 2 (there is no such thing as sata 2) to sata 1 by using a jumper for the hard drive. For exact details, please consult the sticker on the hdd or contact the hdd manufacturer for firmware updates. And please report back, especially if it's a success. (Damn, the VT8237)
Jun 05, 2009 | MSI K8MM-V (MS7142-010) Socket 754 Micro...
M/b cannot recognize SATA HDD
This is common to other mainboards, the SATA controller have it's own BIOS, but it only works correctly using two identical SATA HD's at same time for data protection purposes. If you have a free PCI slot there are expansion cards based on VIA chipset VT6421 with 2 internal SATA ports, other external and one IDE. See one here
May 11, 2009 | MSI K8MM-V Motherboard
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Installation failure- HDD not detected
may be your harddisk is not detected.
check in bios settings.
and disable sata otion .then try.
Dec 29, 2008 | HP 530 Notebook PC
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Hitachi Travelstar 80 GB Hard Drive Logo
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
