Question about Canon imageRUNNER C3200 Copier
Error 000001-003 when the printer is switched on, it keeps bringing this error, switching off and on from the right hand switch is not working, error keeps coming back, i can't print or photocopy any documents
  • corporatepro Jan 19, 2009
    Error 000001-004
  • corporatepro Jan 23, 2009
    paper keeps jamming in the fuser unit
  • 134 Answers
This is a fuser error, that can be resolved by resetting the error in service mode. Or there could be an issue with the fuser, either way you will need a canon technician to repair it.
Posted on Dec 22, 2008
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Cant clear Error Code E161-403E on canon iPF605
to enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
later go to maintenance menu choice replace print head.
then follow their picture image to replace the print head.
first try to print nozzle check in services mode.
Scroll right to the service mode box (rightmost box) and press OK. You should then see the word 'DISPLAY'. Scroll right until you see the choice 'ADJUST' appear. Then scroll down until you see the choice 'NOZZLE 1' appear and press OK. If you haven't already loaded paper, the printer will prompt you to do so and then it will print out the NOZZLE CHECK PATTERN.
check go any nozzle no firing out ink..
Dec 06, 2011 | Canon imagePROGRAF IPF605 InkJet Plotter...
My whirlpool duet keeps getting the f35 error code. I have checked the drain motor filter (found hair pin) & drain lines are clear. After taking it apart I can get it to work about 3 times then it...
Hi
The "F35" error code is indicating a problem with the ANALOG PRESSURE SENSOR switch operation .There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. (See image) The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps getting and F35 error code and stopping
Hope this helps.. The "F35" error code is indicating a problem with the analog pressure sensorswitch operation (key#20). There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. The air dome is located on the back of the tub on theleft hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Jun 20, 2011 | Maytag Washing Machines
How do you print a test page on epson stylus r265 without being conected to a computer
Hi
I only know most printers can do test print by switching off first then hold down to of your switches together and keep hold and then switch on the printer for 5 or so secs but I not sure off hand what ones so try different ones till it works
All the Best: Pineworks
Jan 28, 2010 | Epson Stylus R265 InkJet Photo Printer
The resume button keeps flashing even after I shut off printer, and won't allow me to print. I turned off and on the printer several times. I don't get an error message. All ink is OK.
Make sure the ink cartridge cover is properly closed.
My sister's printer had a similar problem and on initial inspection the cover seemed to be closed, however a small bit of the plastic clip that holds the cover closed had snapped off and therefore wasn't holding the cover properly closed and the sensing micro switch that tells the printer the hatch is closed wasn't being activated.
Not very scientific and a bit of a bodge, but some suitably placed selotape / duct tape / insulating tape to hold the cover firmly closed did the trick.
Hope this helps.
Aug 11, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
Sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
Dell 922 "cover open" problem / error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then close the printer after it powers on.
It worked for me.
Dec 04, 2007 | Dell 922 All-In-One InkJet Printer
Canon imageRUNNER C3200 Copier Logo
131 people viewed this question
old marine
old marine
