Question about Nintendo Wii Console
Problem with wii remote..
I bought this wii remote the other day and when i tried to connect it, it was ok.. but then the sensor keeps on dissappearing then it turns on again.. when i play wii sports, all the games are fine except wen u put in the nunchuck for boxing, it wont connect.. pls help me. tnx much
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
Wii
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Please
Dec 14, 2017 | Nintendo Wii Console
No response to remotes
if the batteries are down change them if it still doesnt work then walk to your console at the left of where to put the disc open the cover and open the cover in where you put the remote batteries and then press sync in the wii remote and wii console just click them dont keep pushing the for more that 10 seconds or everything that is on will turn of except the wii it may not work if it doesnt ask the question for me helper9 that it still doesnt work
Feb 13, 2010 | Nintendo Wii Console
We just bought new wee remote and it will not
Have you checked the remote sensor strip that you mount on the TV is there? Is it connected to the WII console?
Dec 28, 2009 | Nintendo Wii Console
Wii set up problem
that happens all the time, you just have to keep trying it took me 20 minutes once
Sep 27, 2009 | Nintendo Wii Console
Wii remote will not work new batteries just blink all
Hey Jack, How many remotes are you able to connect at a time? If you have multiple remotes try turning the ones you know that work off, and putting them in another room(so you know they will not try to connect). Then try connecting with the bad one. If that doesn't work you might have to sync the remote: hold down the red sync button on the wii, located next to the sd card slot, while holding down the red button on the remote, located under the battery cover on the back. Now try connecting. If it still doesn't work, the LED lights in the sensor bar might have burned out, this happens a lot when you keep your sensor bar directly on your tv without the stand(the tv gets hot and burns out the lights), a lot of people do this because the stand looks bad. Go buy a new sensor bar, they sell them at wal-mart for $20, plus they're wireless, so you don't have to worry about that thin little wire popping. Test the new wii bar, if it's still not working, then you're remote is just worthy of getting returned.
hope this helps! -cj
Aug 21, 2009 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
Wii Remotes not connecting ever!!!
see any obstacles are in the middle of it or radio waves effecting its freqency. or the remote may be damaged
Apr 28, 2009 | Nintendo Wii Console
REMOTES AREN'T CONNECTING TO WII CONSOLE
Try this:
Turn off your wii and unplug it.
Wait a few seconds and plug it and turn it on.
Open the cover in fron of the wii and push the red button for a few seconds.
Now take the lid off the back of your wiimote and below the batteries there is a red button, press it and the leds that indicate what number player you are should start blnking.
Press the red button on the wii again and now the light in the wiimote should stay on.
Test your wiimote.
Mar 17, 2009 | Nintendo Wii Console
Wii remote hand not showing up on screen
on the front of the wii theres a red button you have to keep you finger on that for 5 seconds and try again this has to be done everytime u have to sinc a different device.
May 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
106 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
