Question about Proview PL913B 19" Flat Panel LCD Monitor
Screen not working properly
My screen tuens on flickers no screen thenturns off on to standby. nothing i try solves the problem
Hey guys i have the 2second problem aswell but!, i was just about to throw mines away when i can stumbled across away how to get it working proper again and again and again!. ive seen lots of help pages like this where everyone is talkin about replacing parts, but if u screen flicks on and then off it should work with my quick fix. heres how and i hope it works for you.
Boot up ur pc as u would usually and wait awhile untill you think everything has loaded up or has reached the logon stage.
Then if you look carefully at ur screen and press the menu button you should be able to see it thery faintly (i shine a lamp at it to see better).
Then i cycle through OSD (on screen disply) menu using the up or down buttons on my monitor untill i see the "AUTO" option. at this stage i press MENU button "2 times"
Then i cycle through the OSD untill i see the "RESET" option and again i press the MENU button to confirm the reset.
Then simply press the power button to switch it off and then back on....HEY PRESTO! it working again.
I have told 11 people this fix and they all reported back that it works for them 2. this method should work every time aslong as you stiil can see the green LED on ur monitor.
Posted on Jun 13, 2009
Tv is stuck on standby. The standby light (red) is steady and when I press the STANDBY button, nothing happens. no response or flashing light.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 11, 2015 | Televison & Video
Sometimes notebook display flickers and goes stand by
it shows the display drivers does not load properly, re-installation of video driver may solve the issue
Jan 11, 2013 | Computers & Internet
My tv has been just switching on to standby by itsself recently and today all channels are constantly flickering. I've tried swapping from hdmi to scart but nothing has helped
hi i have a clarity 37 inch flatscreen and it.s on for about 1 hour then turns off then every 10 mins after that can u solve my problom.....
Feb 12, 2011 | Clarity Televison & Video
My laptop britness is not working properly
Is it flickering, or just having promblem adjusting the brightness? If is is flickering, it could be a loose wiring connection. If it is not adjusting brightness, check via using your FN keys, then try clicking the battery icon in your taskbar and adjust brightness through it. If nothing happens, it could be your screen inverter.
Jan 20, 2011 | Samsung R530 Notebook
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
Power light flickers 6 times then goes to standby
It may gone into standby mode because it sensing over current draw or short circuits such as the backlight inverter board. You will need to open it up and look inside the power supply and the backlight inverter board, right now the 5vdc standby power supply is working but nothing else.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Jul 29, 2010 | Sylvania LD370SS8 37 in. LCD Television
Samsung SynchMaster 940MW, flickering
Well thats not promising is it
A wild guess here is that the optrics board has failed. If you take the back off can you smell burned electrics. look on the circuit to see if you can detect burn or browned capacitors. Depending on age and value of the set it might be time to replace it.
Please rate our help to keep the FREE service online ++++
Aug 31, 2009 | Televison & Video
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Proview PL913B 19" Flat Panel LCD Monitor Logo
235 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Bastian Farkash
Bastian Farkash
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
