Question about Panasonic Televison & Video
Panasonic Plasma TV m# pdp503pu
I pushed on button on remote yesterday and heard a pop, like a fuse blowing, TV didn't come on and in lower left corner green lite that usually is on whn tv is on was flashing red. I unplugged TV, vaccummed all vents and tried again 1 hour later, still no screen. Is this a costly fix or should I go get one ?
VR,
Bill
    New Friend:
It seems that tv's fues is blown. May be due to internal shortcircuit ( dust accumulation on the pcb and humidity)or some capacitor is short. I think it will not be a costly job. Go and get it done by a good service person. Better you contact Panasonic authorised service station.
Raj Dave
Posted on Oct 24, 2017
rasadam
  • 5 Answers
SOURCE: Blue screen and red padlock
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
Posted on Jan 24, 2007
techman
  • 3130 Answers
SOURCE: tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Posted on Jul 22, 2007
skotkolr
  • 558 Answers
SOURCE: funai 32 inch plasma tv
bad components on the power board needs to have service tech look into blown capacitors or transformer on the power board inside the tv.
Posted on May 28, 2008
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
  • 718 Answers
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
Tv wont turn on
you dont have any solutions you get to go in a service I have a problem like that and this was the only solution
Dec 15, 2013 | Panasonic TH-50PX75U Plasma HDTV
My Panasonic TH-50PZ7OOU will not turn on. The red light on the lower left is on, but the screen is completely dark. pressing power button on both TV and Remote control gets no response.
Try to power it up with the remote control. When you hear the relay's click, see how many times the red light flashes. This will tell us what the fault is.
Apr 22, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
I can't find the jump button on my panasonic remote control. Is there such a button on the remote control which can jjump between two channel?
Should be a button on the bottom left of the remote labeled R-TUNE. That will send you to the last previously viewed channel.
Dec 24, 2010 | Panasonic Viera TH-42PX80U Plasma TV
The tv was left on and gone off wit a red led showing under the clock on the front of the tv due too the remote being broken we dont know how to put the tv on
On the right side of the tv bazel frame have manual buttons,like a power button,like 2 channels buttons one for up and one for down and a Meneu button.Push the tv manual power button,ur tv should have power and tv will be on.Or try website like Remotes.com to buy a new remote same as ur original tv remote.
Dec 02, 2010 | Panasonic VIERA TH-37PX80B 37 in. Plasma...
I have a 3 yr old Panasonic 42" Plasma
it might be coming from the actual audio/video source. try hooking up a dvd player or gaming system and see if it still does it.
Jul 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Panasonic TH-42px75u Audio went out
re program remote codes 018,016,007,049,067,074,076.
you have to take your remote settings to default
Sep 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
50"lg plasma tv
The popping noise you heard it's probably a capacitor blowing up in the power supply circuitry. If the TV is less than one year old, still covered under manufacturers warranty.
Let me know if you need any more assistant let me know.
Feb 28, 2008 | LG 50PX1D 50 in. Plasma Television
Televison & Video Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
