Question about Emerson MS3100 3-Disc CD Changer
Emerson M3100 Hello! This player is a 3 CD player. They all mount on the front surface. One puts the CD directly on its "nest". A glass door closes down over them. I was able to help the situation by pulling out the head on which the CD rests, and straightening it out. It still makes some noise on that third CD but it now plays. I did the same for the middle one, and it did improve. I am not sure how kosher my technique was, but I did note that the nest floats with the rest of the assembly. If there are other things I could/should be doing, would appreciate knowing. TY Dave
3 Suggested Answers
SOURCE: CD door
try cleaning the mode swith that opereates the dorrs it sounds like its dirty
Posted on Jul 05, 2007
  • 21 Answers
SOURCE: Emerson 3 Compact Disc Player
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Posted on Dec 11, 2010
My cd player door opens then close then stays open
The disc loading mechanism is faulty. Check the loading belt first. Replace it. If this do not help you, replace the disc loading mechanism. if you are not handy, seek tech support.
Jun 04, 2012 | Emerson MS3100 3-Disc CD Changer
Hello Is it possible to remove the glass door panels for cleaning? I can remove the door but I want to clean the glass panels separately. Many thanks Jill
With the door removed, I would suggest to lay it on a flat surface, look at the door around the edges. Normally you can see 2-3 screws around the bottom and 2-3 screws around the top edge. By removing them you can disassemble the door. Be-careful as you disassemble the door, pay close attention to how it can apart to reassemble when your done. This job should not require any special tool other then a screwdriver. Do not force anything back together. This should be about a 30-min job or less depending on the cleaning part on the glass. Go luck.. P.S. - it is glass your dealing with, some of the edges can cut you if handle in the wrong unsafe manner.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 08, 2011 | Whirlpool Ovens
How to remove and install the driver side window (just the glass) on a 94 honda prelude
Hi!!
Here is how:
REMOVAL & INSTALLATION
See Figures 1, 2, 3, 4, 5 and 6
  1. Remove the door pad and inner moisture barrier.
  2. If working on the rear window of a sedan, remove the two upper screws securing the center channel. Remove the two lower bolts (in the door) securing the channel and remove it. On some cars, the two screws are concealed below the weatherstrip.
  3. For sedan rear doors, remove the quarter glass. The entire glass and rubber seal may be removed as an assembly from the door.
  4. Lower the door glass until the glass mounting bolts are accessible. One will be easily seen in the large access hole in the door; the other will appear in the smaller, round access hole. Remove the bolts.
  5. Stand next to the inside of the door. Tilt the door glass and remove it through the slot.
  6. On front doors, remove the bolts securing the front run channel, then remove the channel.
  7. Remove the regulator mounting bolts and remove the regulator. On later models, there are additional roller guide bolts to be removed. Mark the roller guide mounting bolts to ease window alignment later.
  8. For power windows, remove the motor from the regulator if desired.
CAUTION The regulator gear will move suddenly when the motor is removed due to action of the large spring. Keep hands well clear.
TO INSTALL, REVERSE DIRECTIONS
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | 1994 Honda Prelude
Need to know how to fix cd draw not closing or opening by itself. Repair places in Brisbane, Queensland Australia
Hello,the most common failure part on that model is simply the belt.Remove the cover,near the front on the bottom is the belt simply remove it and apply alchohol with a qtip to the inside of it to restore its grip. Also to first open the door on the bottom is a slot ,simply put screwdriver in there(while its unplugged )and slide the bar over this will free the door allowing belt access. After belt is cleaned be sure to close the door by hand before plugging it in so it can retime itself.
Dec 12, 2010 | Yamaha CDC600 5Disc CD Changer Player
How to remove the window driver side of toyota corrola 1988
Door Glass and Regulator - REMOVAL & INSTALLATION
Front Door
  1. Disconnect the negative battery cable.
  2. Remove the front door panel to gain access to the regulator assembly.
  3. Remove the service hole cover.
  4. Lower the regulator until the door glass is in the fully open position.
  5. Remove the two glass channel mount bolts.
  6. Pull the glass up and out of the door.
  7. Unbolt and remove the inside door panel frame if so equipped.
  8. If equipped with power windows, disconnect the electrical connector.
  9. Remove the equalizer arm bracket mounting bolts.
  10. Remove the window regulator mounting bolts and the regulator (with the power window motor attached) through the service hole.
To install:
  1. Coat all the window regulator sliding surfaces with multi-purpose grease.
  2. Place the regulator (with the power window motor) through the service hole and secure with the mounting bolts. tighten the bolts to 48 inch lbs. (5 Nm). Attach the power window harness if equipped.
  3. Place the door glass into the door cavity.
  4. Connect the glass to the regulator with the channel mount bolts.
  5. With the equalizer arm, raise the glass to the almost closed position and make sure that the leading and trailing edges of the glass are equally distant from the top of the glass channel. If not, adjust the equalizer arm to achieve an even fit.
  6. Install the service hole cover.
  7. Install the door panel and reconnect the negative battery cable. Check window and door for proper operation.
Hope helps (remember rated and comment this).
Aug 25, 2010 | 1988 Toyota Corolla 4 Door
How do I remove and install a rear passenger side window (manual) in a 1997 Saturn SL1?The window was smashed, and I need to replace it. Thank you so much for your time and help!
Saturn Coupes/Sedans/Wagons 1991-1998 Repair Guide
(see Figures 1, 2, 3 and 4)
  1. Remove the outer door panel assembly. Refer to the sub-procedure under Door Locks, earlier in this section.
  2. For rear doors, loosen the bottom fastener of the rear door stationary window assembly, in order to provide clearance, then apply tape to the lower half of the outboard exposed portion of the stationary window channel. The tape must be applied in order to prevent damage to the paint surface.
  3. Lower the door glass, then use SA9148B, or an equivalent tool, to remove the glass nuts. Push the glass upward and rotate slightly, then remove the glass from the vehicle.
  4. If the regulator is also to be removed, proceed as follows:
    1. Remove the inner door trim panel. Refer to the procedure earlier in this section.
    2. If applicable, unplug the wiring harness from the power regulator.
    3. Except for the rear door, remove the regulator cam bolts.
    4. Drill out the regulator rivets and remove the regulator from the vehicle.
To install:
  1. If removed, install the regulator to the door assembly:
    1. Position the regulator to the door and secure using rivets.
    2. Except for the rear door, install the cam bolts.
    3. If applicable, connect the wiring harness to the regulator.
    4. Install the inner door trim panel to the vehicle.
  2. Install the door glass into the door and over the regulator studs.
  3. Install the glass nuts using tool SA9148B, or equivalent.
  4. Check the door glass for proper operation and alignment.
  5. If necessary, adjust the glass alignment. For rear doors, fore/aft adjustments are made after loosening the B bolts, while in/out adjustments are made when the A bolts are loosened.
  6. Except for the rear doors, glass which is not running parallel to the door header may be adjusted after loosening the inner panel cam attachment bolts and adjusting the cam. If the glass is floating in the opening, lower the glass 3 / 4 downward, loosen the front guide fasteners, push the glass rearward to seat it in the rear channel, then bring the front glass guide back to the front edge of the glass. Apply a light finger pressure on the guide and tighten the fasteners.
  7. Once the glass has been properly adjusted and is operating smoothly, install the outer door panel assembly.
Fig. 1: Remove the glass nuts using a suitable tool-front door shown
Fig. 2: Exploded view of the regulator mounting-except rear door
Fig. 3: Exploded view of the rear door regulator mounting
Fig. 4: Adjustments of rear door glass are made after loosening the A or B bolts
I hope help with this (remember rated this help) Good luck.
Oct 16, 2009 | 1997 Saturn SL
CD PLAYER NOT WORKING
1. make sure you have the cord/batteries inserted the right way.
2. make sure that you have the power to the cd. which is slide the button to the cd, or put the button where the cd is..
3. open the cd
4. place the cd in with the label up
5. close the cd
6. on the front you should see the tracks that it has
7. if it does, just hit play and you should be able to hear the disk moving
let me know if this helps.
Oct 25, 2008 | Emerson PD6810 CD Boombox
Wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Jun 28, 2008 | Televison & Video
Front door won't open
open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
if the door doesnt open means just hit on upside surface lightly after pressing eject button only...
Feb 03, 2008 | Technics SL-MC700 110-Disc CD Changer
CD door
Nov 15, 2006 | Emerson MS3100 3-Disc CD Changer
Emerson MS3100 3-Disc CD Changer Logo
49 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
