Question about HP L2208W Monitor
When i switch the moniter on i see faint lines running up my moniter ( very faint ) as if they are some kind of interference lines, my colleagues are using the same screen on the tables next to me but have no problems on theirs. could this be a settings issue?
  • karun_bali Dec 23, 2008
    i tried no.1 but it didnt work
    i will try no.2 next
    thanx.
  • 191 Answers
Hi this shows your monitor has a interference by:
1) by screen refurbish frequency you may try to change this frequency from PC, go to screen setting go high level setting click monitor and change the frequency to 70(or other than 60) ,also you may try from your monitor.
2)stil trouble there, your monitor has a problem with power supply,
the capacity wave filter not very good condition. need to change 5V wave filter capacity (two),should be solved.
Posted on Dec 22, 2008
Cameras have some kind of interference
This can be caused by power supplies being overloaded or the camera signal line is running close to other power cables. also if you have LED lights some types emit a frequency that can affect both wired and Wireless type cameras. try switching diferent units or lights off to see any change occurs.
Dec 31, 2015 | SWANN Home Security
Samsung LCD suffering from faint white lines scrolling, and buzz
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 22, 2017 | Samsung LN-S3251D 32 in. LCD HDTV
Computer will not boot up
no most popularly its because u have filled up the ram slots some pc need to have the driveres installed to take the ram try taking all the ram out apart from one stick in slot one the turn the monitor/tv on and then the pc this should work if i dosent then the pc is booting in too high or too low a resilution normaly too low try using a old moniter jst to set the pc up but try the ram first normally works
Dec 02, 2008 | AMD ASUS A7N8X-VM/400 Motherboard
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Diagonal lines
Well it sounds like that thers and internal issue with the console for this to happen like a harware issue then.
Feb 24, 2008 | Nintendo 64 Console
My screen will not light up
turn power off and back on your moinitor and laptop this should do the trick
Jan 16, 2008 | Averatec 6200 Notebook
Horizantal lines
Had same problem with my PRO1000 - faint horizontal bands moving from bottom up (sometimes sationary). Turned out to be nothing more than some signal interference from a PC I had plugged into the VGA moniter input on the TV. As soon as I disconnected the PC, the bands disappeared. Hope that helps...
Nov 06, 2007 | Pioneer PureVision Pro-1000HD 50 in....
Amilo pro, Fujitsu (siemens)
sounds like the LCD lamp burned out.
Nov 04, 2007 | Fujitsu V2000 (9052026) PC Notebook
HP L2208W Monitor Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
