Question about Acer Altos G700 Server
Acer Altos G700
Server does not Boot either from Floppy or Cd Rom or From Harddriver either Scsi Hot Plugable or Ultrawide It only detect harddrive and cdrom nad gets hangs i have changed ram processor harddrive and have put addon Array Card Plz Suggest some Good Solution
Regards
Zeeshan
  • paulo2 May 11, 2010
    What is the boot order in the bios?
    Do you use internal RAID controller?
    Did you change the internal hard disk drive?
    Master:
  • Acer Master
  • 353 Answers
HI,
I have had this problem on other systems and have had to change out the DVD drive to resolve the problem ...
This I also found ...
ftp://ftp.acer.cz/Archiv/server/AAG700/manual/aa_g700_ug_en.pdf
Posted on Feb 02, 2018
2 Suggested Answers
  • 38 Answers
SOURCE: where can I buy parts
Newegg.com or tigerdirect.com but go with newegg.com best place and I get all my parts there.
Posted on Oct 08, 2009
Altos G520 Server no boot device found
During the POST procedure press "F2" to enter BIOS. Check that all your drives are detected properly and that the Boot sequence of drives is correct and that the drive you should be booting from is near if not at the top of the list.
If these settings are all correct then it looks as if your boot drive has died, or there is no OS installed on the drives selected. Try putting the cd/dvd drive top of the list, and with a Windows installation disk in the drive watch the boot process, and when it comes up with "Press any key to boot from cd/dvd . . ." press a key and see if the disk tries to install windows.
The link below allows you to view the manual
http://www.manualowl.com/m/Acer%20Computers/Altos-G530/Manual/114781
Oct 25, 2013 | Acer Altos G530 Server
Need scsi/raid drivers on floppy to install winxp pro (at f6 prompt)
Hello the drivers can be downloaded here:
http://www.tyan.com/support_download_drivers.aspx?model=S.S2865
You need to unzip the file before you install the driver.
It should not be nessesary to install drivers before installing the windows system.
Check your bios boot settings to boot from the cdrom or dvd drive.
The cd or dvd drive must be the first boot device in order to boot from the windows disk.
Install windows with only one harddrive.
You can also add a harddrive later, when the installation is done and all drivers is installed.
Good luck
Jun 20, 2013 | Tyan Tomcat K8E Motherboard
Populate SCSI-B connector on SE7520BD2V
Intel Bios update information states these as supported functionality:
1. 8 * DIMMs DDRII-400 2. Intel(R) Xeon(TM) Processor with 667MHz/800MHz system bus speed. 3. Multi-boot support. 4. System Flash BIOS ROM 5. COMA/COMB port 6. CD-ROM boot 7. Floppy port 8. PCI 33/66, PCI-X 66/100/133 mode 1, PCI-E x 4, PCI-E x 8, PCI-X 66/100/133 mode 2 slots 9. ATI* Rage* XL VGA 10. Serial ATA 13. Clear CMOS 14. Legacy Power button 15. ACPI S0/S1/S4/S5 15. Setup screen 16. Summary screen during POST 17. Legacy USB keyboard / mouse / Floppy / CDROM / HD 18. ARM (ATAPI Removable Media) / IRM (IDE Removable Media) 19. Custom CMOS load/save 20. BIOS recovery 21. Intel Platform Security 22. Intel Server Management 23. LSI 53C1030 dual channel SCSI 25. Customer CMOS backup/restore 26. IMT support 27. User Binary feature 28. SERR/MERR detection & logging for runtime 29. Int15 for ABS2.0 30. ACPI SPCR (Serial Port Console Redirection) 31. NMI detection for PERR/SERR 32. Rolling BIOS 33. SOL (Serial On Lan) 34. Multi-disk Recovery Item number 23 is this lsi chip: http://www.lsi.com/downloads/Public/SCSI/LSI53C1030/lsi53c1030_pb.pdf
You should locate that chip on the board, The information in the bios update functionality lists that as being functional; however I'm not certain if they mean you can put that lsi chip on professionally or if its there and you would just need to populate the connector to use it. I'm not sure if a bios update is required, they didn't mention that in any of the actual features added to the update, and they say that if updating the bios doesn't fix something, then you shouldn't attempt to update it anyway.
But a whole other issue is whether or not you should physically solder in a new connector or do you mean populated as in a wire is not plugged into a connector and going to a scsi hard drive
May 19, 2012 | Intel SE7520BD2 Motherboard
Operating system not found
I recommend going into your BIOS and making sure your system is detecting the hard drive(s). If not, recheck your cable connection at the drive and the board. If it is detecting the drive, make sure it is set to be one of the boot drives(I would make it 2nd to the CD-ROM) and reboot your server. If you get the same error, you will need to reinstall the os.
Good Luck
C2Solutions
Nov 25, 2011 | Acer Altos G540 Server (G540-50039)
Acer server continous beep sound
check if the memory of your server is connected properly or replace new memory for your memory... :))
Feb 23, 2011 | Acer Altos G700 Server
1.how to reset bios password ? without opening cabinet? 2.where can i get the user manual ?
1. Without opening the cabinet, you can start the computer, and enter the current password.
Then, you can change the password.
2. From the manufacturer's web-site: http://www.acer.ca/acer/service.do
Select Driver Download
Select Server
Select Altos
Select G700
Select "User Manual Acer User Manual 1.0 14.8 MB 2009/01/16"
Jun 15, 2010 | Acer Altos G700 Server
Installation de win nt 4 sur acer altos 600. en effet le probleme c'est qu'and on commance l'installation, il demande d'ajouter des SCSI sur disquettes, et lors de l'extraction des SCSI des disque dure (CD...
Si vous essayez d'installer Win NT, vous pourriez ne pas avoir de support; pas beaucoup de gens l'utilise et la nouvelle g?n?ration informatique pourrait m?me ne pas savoir comment vous aider ? l'installer, sp?cialement avec des "disquettes".
Dec 14, 2017 | Acer Altos 600 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
How to repair server 2003 in IBM 226 server
first you need to prepare the scsi drives ie host raid adapter scsi drivers are server raid cotroller 6 scsi drivers by using the serevr raid support cd dikettitools proper os drivers to floppy and boot with widows cd at the time starting boot press f6 to specify the scsi drivers then all scsi hdd will detect for installatio.
Jan 18, 2010 | IBM xSeries 226 Server
Where can I buy parts for acer altos g700?
Oct 08, 2009 | Acer Altos G700 Server
Acer Altos G700 Server Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
