I have bought a second hand quinny speedi system pram and pushchair. I dont have anything to fasten the black bassinet/pram into the frame. I think it is missing and the old owner is living in Germany. Is there any way that I can buy the missing parts?
All you need are the speedi adapters which you can buy for about £12 or so off ebay dont go through dorel for these as new they will cost you closer to £30 for two peieces of plastic hope this helps x
The quinny speedi should come with the adaptors to fit the bassinet (the quinny dreami) Once you remove the pushchair seat unit by undoing the clips and undoing the velcro the fastenings you then need to remove the 2covers or bumper bar(depends on model) above the quinny logo on the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. The carrycot is then place onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood.
HTH
Yes you can.
You need a set of adaptors( the same ones as for attaching a maxi cosi car seat)
You remove the seat unit by unbuckling all straps and taking it off.
Then you then need to remove the 2covers above the quinny logo on the sides of the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. They are marked left and right. The carrycot is then placed onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood. HTH
Unclip your arms and fold your pram down, once the pram is half folded at the hinge point you will see a little push button push this in and slide the inside part up towards the top of the pram, this will remove the case then you just click your brackets in. If you go to the Quinny website you can download a manual which has pictures.
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do. 1) put the foot brake on so the rear wheels wont turn. 2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down. 3) pull this handle out to its tallest position 4) Hold the handle and press the button mentioned at the start in and hold it in 5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
