Question about Lasko 5540 Ceramic Compact Heater
Honeywell my honeywell heater keeps shutting the power off in the house? Help
    Scholar:
  • 75 Answers
You have too many things on the circuit you are on. Either move it to a different plug, or turn some things off. A plug in heater uses as much electricity as the breaker should carry if it is a 15 amp, like most are. Try to find a plug on a different circuit, or clear some things off of it.
Posted on Dec 22, 2008
After filling oil tank, turned heater on. does not shut off at 70, keeps running. have to shut heater by emer. shutoff-bad thermostat
Here is the user manual for your unit.
https://www.manualowl.com/m/Honeywell/CT87B/Manual/134033
Look at parts 7&8 of the manual. In section 8 there is a notation about the anticipator pointer adjustment that should solve your problem.
Nov 22, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
Power company had to shut power off to my community. When power came back on several hours later its still a blank display and does not work. I have turned off and on every circuit breaker I have in my...
cefb7e0c-979f-4b1a-bff6-c84fcbc4c9cf.pngYou will need a meter and test for 24 volts at red and common, if present, you next need to check at yellow and common and green and common, green being fan and yellow being ac outside.
I suspect the transformer is not providing the 24 volt control power to the stat either due to the high voltage or a low voltage fuse has blown on the board usually a 3 amp auto type, beyond this I am unable to offer much help .
Aug 25, 2013 | Honeywell Programmable Thermostat Heater
The thermostat is programed to go only up to 73 degrees but it keeps going and it starts getting really hot in the house, is soo annoying. I have to get up in the middle of the night to fix it by pressing...
If t'stat is overshooting your set temp but you can reset or otherwise shut it off, then you need to replace the t'stat. If you can't get it to shut off by resetting t'stat , then the problem could be in your heater.
Jan 12, 2011 | Honeywell Programmable Thermostat Heater
What is the best place to put in a manual honeywell thermostat in a house with one zone? I have a boiler raduater. I like to keep the heat the same in all rooms.
on an inside wall - large(est) room - near center of house - out of direct sunlight - not in or near kitchen, bath, appliance, light, or anything else that makes heat - approx 60" from floor - not close to a supply air (above a return air is GOOD)
Oct 18, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
I have a Honeywell CT3200A1001 in my home, I need help! It kicks on but won't heat the house passed 71 degrees. The furnace seems fine but the thermostat just keeps turning it on and off with no results...
try replacing the battery in the thermostat i am not familiar with this particular model but had a similar problem in my home replaced battery and now works good
Oct 10, 2009 | Honeywell Electronic Programmable...
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Lasko 5540 Ceramic Compact Heater Logo
99 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
