Have an RCA Colortrak 2000. All is working but picture has been reduced to a thin line (about 1") in the center of the screen. I can't use manual or remote buttons to fix picture size because the TV image is so thin that I can't make out menu selections to try & fix. PLEASE HELP !! Only TV I have.
  • kwes Dec 22, 2008
  • kwes Dec 22, 2008
    Model # is FLR2622T. Previous response suggested DIY help involving soldering -- definitely not my arena. Could do with on-line help ASAP or svc repair tech to my home.
    Genius:
  • 1,139 Answers
Hello kwes,
First of all do not run the TV in this condition, you will burn the image into the CRTs.
Second you have a failure of your vertical deflection section. This could be the drive signal to the koke transformers has malfunctioned, or the actual drive signal from the vertical output section has been removed either by the vertical coupling capacitor malfunctioning or the drive IC has malfunctioned.
In any event this is most likely the cause of your problem.
I would suggest that you have a qualified TV repair technician give you an estimate on the repair, unless you want to try to repair this yourself. If you have a background in electronics you can try the do it yourself route if not my sugestion still stands about haveing the TV technician do the job for you.
Either way it's your choice.
I might be able to give you the schematics if you need them.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 22, 2008
  • 10,594 Answers
Symptoms shows few capacitors are weak in vertical deflection circuit and require replacement.
Let me know exact model number to help you better.
  • Shahid Electronics
    Shahid Electronics Dec 22, 2008
    Please take this TV to local repair shop and qualified TV tech will fix it by replacing few capacitors in vertical deflection section.
    Of course if you have no experience of TV repair then should not try it as electric shock risk is involve in TV repair.
    Good luck.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your described problem indicates a vertical deflection failure. It is most likely the vertical output IC.
Are you considering a DIY (do-it-yourself)? If yes, pls post back availability of soldering iron, soldering lead, desolderer and a DVM or VOM.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 22, 2008
    If you are alternately seeking the services of a qualified professional, pls postback your zipcode and general location.
    But of course you would no longer see this post. Again, goodluck to your concern.
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
Rca colortrak 2000 manual
You may be able to get a manual by requesting it directly from RCA.
Jul 28, 2014 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
I have a RCA colortrak 2000 picture tube TV . There is one horizontal white line in the middle of the black screen
You have a vertical problem, caused by vertical deflections circuit failure, can involve a number of parts to fix.
Jan 03, 2011 | RCA Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Old RCA ColorTrak
HELLO. YES U CAN IF YOU CAN GET A DEGAUSSER.!!! U CAN GO ON LINE AND FIND OUT HOW TO MAKE ONE AT UTUBE.COM. TYPE IN HOW TO MAKE A DEGAUSSER COLE.!! THEN FIND OUT HOW TO USE IT.!!! THERE ALSO.!!! GOOD LUCK.!!
Jun 22, 2008 | RCA Televison & Video
TV - Thin horizontal line picture on screen
Is this a LCD TV? IF it is it could be something on the video processing board. Let me know the model # and well will go from there. Thank you Jay
Jan 31, 2008 | Televison & Video
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer menu...............you can try turning down the
screen control a bit....................T.
Dec 21, 2007 | RCA F36650 36" TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
1987 RCA Colortrak 2000 Television
Line 1 is Channel 91, Line 2 is Channel 92 - you can select them directly using the remote
Sep 17, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
