Hi, I have a Vespa 1967 fully restored but just av a problem with the engine cutting out after around 40secs. It runs perfectly when starting. To get the engine running again I have to take the plug out, turn the fuel off and crank it over a few times, then put the plug back in and then again turn the fuel back on and its starts more or less first kick. Anyone know what this could be?? Thanks.
Did you put back the choke (under fuel switch)
- and better rev once high in neutral after succesful start until engine gets warm
Posted on Sep 28, 2014
Getting to much fuel apparently.But have never seen or heard of one of these.
Posted on Dec 23, 2008
If you have weak spark it will run for a short time and then flood out.
Is the plug gapped correctly? Is it the right plug? Can you screw in the idle jet all the way on a fresh plug and have it not start? If it still acts the same way fuel is getting in without it being metered. The exhausted could be resricted not letting the engine exhale. If this was the case it would have a very hard time holding high rpm's for an extended period. Might have more info for you if any of these things change your situation
If the float setting is too high in the carb it will not shut off fuel in the bowl and flood excessivly.did you rebuild the carb with all new parts I've seen floats that were not cork absorb fuel and become heavy and never shut off the needle to seat seal and fuel just keeps on running through the carb. We could chat on cell phone also.
Aug 24, 2014 | Peg Perego Vespa Scooter
Jan 14, 2014 | Vespa Motorcycles
Feb 27, 2013 | Vespa ET4 125 Motorcycles
Sep 17, 2012 | Cars & Trucks
May 10, 2012 | Mitsubishi Pajero Cars & Trucks
Nov 23, 2017 | 2007 Vespa GT 200
Apr 13, 2011 | Peg Perego Vespa Scooter
May 29, 2009 | Peg Perego Vespa Scooter
Mar 27, 2009 | Gilera Runner VX 125 Motorcycles
Oct 10, 2017 | Peg Perego Vespa Scooter
1,229 people viewed this question
Thanks, thats what I thought but Ive had the carburetta apart made sure the choke spring isnt sticking and adjusted the idle screw as much as possible and it still does it! not sure how to really decrease the amount of fuel anymore! Any ideas?
Thanks for your comment, I did rebuild the carb with all new parts but the float/needle I fitted was to long which meant the needle restricted the amount of fuel getting through to the carb when the bike was running. I shortened the needle taking off only about a millimetre and this seems to have sorted the problem. Thanks again.
