Question about ISI Thomson Scientific Computers & Internet
Bookmark not definied when inserting citation from ProCite > Word
When I want to insert a citation from ProCite 5, into Word 2003 (Dutch version) with the Cite while you write funtion from ProCite:
Something like this appears, where it should be just (Author, year of publication)
__________________________________________________________
{#MLV23}kÿ\11\05‘\19\02\00\00\00\08{#MLV23}\00\08\00\17\00\00\00@C:\5CProgram Files\5Cartikels\5CProCite5\5CDatabase\5Cjournal articles.pdt#Brinkman, Duyts, et al. 2005 #MLV23\01\04\00\08\00àà\00\00\00¿H\0007\14\00\14\00\00\00\01\00\00\00\00\00\00\00\00\00\00\00\10\00\00\00\00\00\00\00\02\00\00\00\00\00\00\00\00\00,\00\00\00\01\00\00\00Lô\12\00=\11J\00,\00\00\00xô\12\00Lô\12\00\05\00àà\00\00\00¿H\0007\14\00\14\00\00\00\01\00\00\00\00\00\00\00\00\00\00\00\10\00\00\00\00\00\00\00\14\00\00\00\00\00\00ÿÿÿîã¿wçã¿w,\00\00\00Dò\12\00.ä¿w,\00\00\00\00\00\00\00 kFout! Bladwijzer niet gedefinieerd.kFout! Bladwijzer niet gedefinieerd.
(Bladwijzer not definied means here Boodmark not definied)
The function dusplay bookmarks is active
Thanks in advance
SOURCE: Accessing bookmarks from Creative Zen
To access a bookmark or have the player jump to the bookmark you must...
1. - Setup your shortcut button to jump to bookmarks
1.1 - From the top level menu, go to "System", then "Player Settings", then "My Shortcut Button".
1.2 - Set the shorcut button to "Jump To"
1.3 - In the "jump to" menu select "Bookmarks"
Ok so now you can easily access your bookmarks... and also the jump feature will now work :)
2. - Simply select your bookmark and then press with the PLAY or center button to access your bookmark.
There may be other ways, but that's the way I did it
Hope it helps.
DOPs
Posted on Jan 23, 2009
szot
  • 24 Answers
SOURCE: cannot bookmark page
Hmm zone alarm should not be stopping you from bookmarking it has no outgoing connections to bookmark so that should have nothing to do with your problem. :)
My first thought is that the bookmarks.html file is read only, this happens sometimes after upgrading your firefox.
  1. Navigate to the profile folder
  2. Find bookmarks.html (you can open it and see if any bookmarks in it saved to make sure this is the right file)
  3. Right-click on the file, choose Properties
  4. On the General tab, make sure "Read only" is not checked.
  5. Press OK.
For help how to find the profile folder:
Operating system Profile folder location(s) Windows NT (NT 4.x, 2000, XP, and Vista) "%APPDATA%\Mozilla\" Windows 95 (without Desktop Update) C:\Windows\Mozilla Windows 95 (with Desktop Update)/98/Me C:\Windows\Application Data\Mozilla\
C:\Windows\Profiles\<Windows login/user name>\Application Data\Mozilla\
Unix/Linux ~/.mozilla/ Mac OS X ~/Library/Mozilla/
~/Library/Application Support/
If this did not help or it was not read only, another known reason for the bookmarks button to stop working is if you have either a non compatible extension/plugin installed or if you have norton antivirus that messes it up (compatibility issues). I would try to troubleshoot this by first slowly disabling one by one the plugins, meaning disable one, restart firefox, see if it solved it. You do it the following way:
1] From menu that is at the top of Firefox window, you need to click on Tools options and then choose Add-ons. Add-ons window will appear.
2] In add-ons window, you have to select Extensions panel to view your installed extensions
3] Check for extensions known to cause problem when they are installed with Norton: These include Piclens, freecorder, FoxyTunes, Google Toolbar, and Skype extension. If you do not have norton then just go one by one slowly disabling for test.
4] Disable one by one each and every extension that you have from list above each time testing if the one you just disabled was responsible
For disabling the extension do the following:
1] Click on the name of that extension to disable
2] To disable this extension, you have to click on disable button.
Repeat the steps given below for each extension that is causing problem.
5] After you have disabled the extension, you have to close Firefox window. Click on file menu and then choose exit.
6] Right click on any empty spot in Windows task bar and then choose Task manager. An alternative way is to press Ctrl + Shift + Esc
7] Select processes tab
8] Select firefox.exe entry in processes list and then press End process. If there is no “firefox.exe” entry then you can skip this step.
9] Start Firefox browser normally
10] Close Firefox browser again. Click on file menu and then choose exit
11] Start Firefox browser again and see if bookmarks works
Alternatively if after disabling all the addons/extensions the bookmark menu still not works, you can always backup your bookmarks file (located in profile folder, see above for exact path), save it somewhere, reinstall firefox completely and import/copy back the bookmarks.
If the above solutions helped you please rate:):) Let me know if it solves it or not, am sure we find the solution:)
Posted on Feb 08, 2009
SOURCE: creative zen mosaic how to bookmark?
To insert a bookmark
  1. Play the track that you want to bookmark.
  2. In the Now Playing view, while the track is playing, press options.jpg and select Set Bookmark.
  3. Select a bookmark number.
    If all 10 bookmark numbers have been assigned, clear an existing bookmark. In the main menu, select Music > Bookmarks. Press options.jpg and select Clear Bookmark.
To go to a bookmark
  1. On the main menu, select Music > Bookmarks. - You have to scroll down to find this!!
  2. Select the bookmark that you want.
Posted on Mar 04, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a GE
The drive belt may have been broken, worn, or has slipped off. Reset the washer then restart a new cycle and check if it will tumble or not. The belt is indeed not in good operating condition should the washer seem to complete the wash cycle but does not tumble or spin.
Unplug the washer for 2 minutes then plug it back in. Open and close the lid seven times to reset the motor and the inverter.
The inverter on the top of the motor flashes a code to indicate a fault. Take the washer front panel off to access the motor and the inverter and see the blinking LED. Look into the seam where the top meets front panel. There is a clip on each side; push a flat head screwdriver into the clip to release it Pull the top of the front panel and slide it up to remove it. Check belt and the LED for the code. Black powdery substance at the base of the washer is a sign that the belt is worn; replace it.
Posted on May 25, 2010
  • 277 Answers
SOURCE: I can"t delete/remove bookmark from
Open your browser and enter the bookmarks menu. Long press the bookmark you want to delete and select "delete/remove bookmark". You may need to scroll down to see this option.
Posted on Mar 01, 2011
Citation troubleshooting
a thermostat does'nt have wire's , it is completely inserted in a housing ,i think you may be talking about temperature sender switch which will have wire's and they should have a connector that corresponds with a connector by the location
May 04, 2014 | Cars & Trucks
Tip
Creative Zen V Plus Bookmarks
A little known feature on this player is the ability to use bookmarks, up to 10 of them. Many of you listen to podcasts or audio books which may be fairly lengthy and if you have to stop in the middle of what ever you're listening to, normally when you go back to your player you would have to start all over again.<br /><br />A note about <span style="font-style: italic;">"resuming playback":</span> If you shutdown during playback of a podcast or audio book (not pausing or stopping playback first) your Zen will automatically resume playback when you start it back up.<br /><br /><span style="font-weight: bold;">Zen V Plus Bookmarking</span><br /><br />You can insert bookmarks during playback. A bookmark helps you mark a point within a track, so you can return to it at a later time.<br /><br />You can use up to 10 bookmarks at any one time.<br /><br /><span style="font-weight: bold;">To insert a bookmark:</span><br /> <ol> <li>In the Now Playing screen, press the Options button and select Set Bookmark .</li> <li>For ZEN V Plus, you will need to press and <span style="text-decoration: underline;">hold</span> the Options button. Playback pauses and the Set Bookmark screen appears.</li> <li>Select a bookmark number.</li> <li>Your bookmark is assigned to the selected bookmark number. If all 10 bookmark numbers have been assigned, you can replace an existing bookmark with the new one or you can delete a previous bookmark.</li></ol><span style="font-weight: bold;">To delete a bookmark:</span><br /><br /> <ol> <li>Press and hold the Menu/Back button. The main menu appears.</li> <li>Select Music Library and then Bookmarks .</li> <li>Go to the bookmark that you want to delete.</li> <li>Press the Options button. For ZEN V Plus, you will need to press and hold the Options button.</li> <li>Select Clear Bookmark.<br /></li></ol><span style="font-weight: bold;">To go to a bookmark:</span><br /> <ol> <li>1. Press and hold the Menu/Back button. The main menu appears.</li> <li>2. Select Music Library and then Bookmarks .</li> <li>3. Select the bookmark that you want.</li></ol>Note: The Bookmark feature is not applicable for contents played from the memory card for players such as ZEN 2GB,4GB,8GB,16GB, 32GB and the ZEN X-Fi Series. ZEN Xtra also supports bookmarks though you cannot place two or more bookmarks for one song or audio book<br /><br />
on Jan 25, 2011 | Creative Labs ZEN V Plus MP3 Player
How to insert a sim
Hi, on the wifi version of iPad. You cannot insert a sim on this unit. The 3G units has a slot for micro sim cards. The wifi version does not have the hardware inside necessary to access 3G networks.
Sorry
Jan 15, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Hi! I bought a Toshiba SA60 laptop through my friend from holland.The language in the windows xp program was in dutch.I reinstalled windows-xp in English language.Can I use the original product key/code of...
hello, the drivers can be downloaded from the same place which is toshiba website. Now I personally have used an english key to install a spanish version of windows xp. I dont know if this would be the case with your version.
Aug 25, 2010 | Toshiba Satellite A60 Notebook
How to give link within word document
Select the word you want to jump TO. From the insert menu select bookmark and name appropriately.
Go to the top, as an example and select the word you want to click on, from the insert menu or toolbar click on Hyperlink (world with link) and from the hyperlink window select Bookmark (right side) AND select the newly created bookmark. If it's not there then it was not created.
May 06, 2010 | Microsoft Windows 98 for PC
Hi, i want to have the dutch spelling of word. i
If you have office on the review page you have a translator in your word processor. You need at least word. or you could go on line and check your words. Otherwise you would have to purchase word at least.
Feb 09, 2010 | Microsoft Windows? Vista Home Basic...
I have bought some new games. When I inserted one
Each game has it's own flash memory to store settings and save games, maybe that flash memory is defective.
To learn Dutch is also not so bad. :P
Return to the store where bought the game, show them
that it not doing what it is suposed to do.
Succes.
Oct 28, 2009 | Nintendo DS Lite Console
I can figure out how to set a bookmark but I can't figure out how to select one to play. Help please. Thanks
A bookmark marks a point within a track, so you can return to it at a later time.
For example, if you are listening to your recording of an interview, insert a bookmark if you need to stop halfway through. When you want to continue listening from where you left off, go to this bookmark.
To go to a bookmark
Oct 09, 2009 | Creative Labs Creative Technology Zen MP3...
Creative zen mosaic how to bookmark?
To go to a bookmark
Feb 27, 2009 | Creative Labs Creative Technology Zen MP3...
Inserting landscape paper
In most versions of word, to make page 2 of 3 appear landscape instead of portrait.
Create page 1 - assuming the default is portrait
then when near the bottom of page 1 do drop down menu Insert->Break and choose Next Page.
Then on the new page choose menu File->Page setup and select 'Landscape' on the margins tab.
then - when at the bottom of page 2(Lanscape) do drop down menu Insert->Break and choose Next Page.
Then on page three choose menu File->Page setup and select 'Portrait'on the margins tab.
Jun 20, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
37 people viewed this question
Top ISI Thomson Scientific Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an ISI Thomson Scientific Computer and Internet Expert? Answer questions, earn points and help others
