Rp40tv pannel lock no remote
I have tried universal remotes cannot get into menu to remove pannel lock can you help?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a universal remote does not have all the necessary buttons to program/control all the functions necessary for the operation of the Bush RP40TV 40" Rear Projection Television. What is required is an original remote control or a direct replacement remote control.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
Child locked on my tv
Possibly, you will need an original remote to disable or turn off this feature. And some child lock can be accessible through neither MENU of your tv or remote. Check CHILD LOCK option to remove it. If it is a screen lock type of CHILD LOCK feature of tv (a Blue Background display a LOCK icon) and your original remote is lost, try a universal remote for you to possibly unlock it. Thanks for using Fixya.
Apr 21, 2014 | Televison & Video
Parental control locked how do I unlock them RCA model 13V420T
hello!if nobody "tweak" your codes, try 1111 or 0000. You need to be able to access "menu' off your remote control. Make sure, universal remote matches the manufactures. Better odds to hit "menu". good luck,Alex.
Feb 01, 2012 | RCA Televison & Video
Just bought a second hand philips 20hf5474 with universal remote but no user manuel. cannot get into menu to set channels, clock etc
Hello philbarbara:
Here is the link for the manual for your Television:
"CLICK HERE"
It looks like this set has a lock for the menu which can be accessed only with the remote. Hopefully its not locked out.
But it also looks like you have buttons on top of your set. In which case you should be able to access the menu button from there.
As far as your universal remote goes, you might need to try a different code in order to control your televisions menu settings. Some codes only control on, off, volume etc. If you put the right code in your universal remote you should be able to get all of your remote functions.
You also might want to try watching out on Ebay for your remote that goes to your particular TV set. That would be the easiest way to solve your problem.
With the manual link I've provided for you, you should be able to solve this dilemma your in.
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Mar 26, 2011 | Philips Televison & Video
Unlockint the rca truflat
just had the same problem... found the old RCA remote in my house... put new batteries in it...used RCA remote.... hit menu... arrow down to preferences and hit "ok" on remote.....use arrow again to go down to FPA lock and hit ok to turn it off, hope this helps, hit menu again to remove menu from your screen
Brenda
Dec 29, 2008 | RCA TruFlat 27F520T 27" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
Front panel locked and remote don't work
To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Mar 22, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Nov 03, 2006 | RCA 14F512T 14" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
