Question about Compaq Presario Notebook
Compaq presario v6000, all the lights on but laptop not starting
No post nothing coming up
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
My Compaq v6000 notebook doesnt power on it just
You could be having a problem with your power source....(not the plugin) but the actual power unit inside of the laptop. Or could be dirty inside and sometimes they get touchy with a lot of dust build up. Try cleaning out the inside of the laptop be removing some panels on the bottom and the keyboard. Try using a can of air to blow the crud out.
You can also take it to a shop and have them test the power source.
Sep 19, 2009 | Compaq Presario Notebook
Not starting up
sounds like a dead processor
Jun 14, 2009 | Compaq Presario Notebook
I need for my compaq presario v6000.
You can get the wireless drivers in the laptop itself. U need to type in the start search as recovery manager and when the window is opened, click on the advanced options and select the option hardware driver installation. Search for the sound driver and select it and it get re-installed. If this doesnt work try to go to hp.com and select support and drivers and enter the product number of the laptop and follow the onscreen instructions.
Thanks and Regards
Honey
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
Jul 31, 2008 | HP Compaq Presario V6000T Notebook
Presario V6000 laptop
sounds like a motherboard issue ,
can you take the drive to another computer and check the contents are still accessible.
If contents are accesible then the motherboard is poked.
replace device and start again.
There is no cheap fix for this one unfortunately.
Keep me posted with your outcome thanks
Jul 20, 2008 | HP Compaq Presario V6000T Notebook
usually all drivers for Compaq and HP computer systems (portable and non-portable) can be found on the HP support website (Click here to go to it), simply go there, chose your region, than your country, enter your model number (not the series, the model number, you would usually find it on the service tag, or wherever you would find a serial number), but be sure to chose "Download drivers and software (and firmware)", and than chose your operating system. Hope this has helped.
Jul 06, 2008 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Compaq presario v6000 s/n: cnf6412pn1
Compaq Presario V6000 AUDIO SOUND DRIVERS HOW TO GET
Mar 15, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario Notebook Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
